Installing MGW Shifter
drenath
Low MPH - Rand Road Crew
Jul 25, 2005
1,114
Took me 25minutes in a parking lot with a basic ratchet set. Only tough part is breaking the old shifter off once its unbolted. Really gotta pull HARD. I had to bolt up the old handle and kick it. Make sure you use the bolts MGW gives you - do not re use the stock bolts.
-=SVT=-
Gold Member
Apr 20, 2006
2,194
Hit it right on the nose with this post! It is easy with the exception of getting the old one off.:biggthump
27,984
Avoid getting any of the old sealant in the trans. Take your time cleaning off any sealant so you get a good fresh mating surface. As mentioned, it's a simple install.
I had to pull mine on and off half a dozen times due to a problem with the spring on the 1st gear side. The people at MGW were very good at customer service. They sent me replacement springs which didn't help and then a new shifter which resoved the problem. I'd highly recommend both the shifter and MGW.
