Installing MGW Shifter
spike0284
I should be receiving my MGW shifter by the end of this week. Just wondering how easy is it to install? Never done this before.
Thanks,
drenath
Low MPH - Rand Road Crew
Took me 25minutes in a parking lot with a basic ratchet set. Only tough part is breaking the old shifter off once its unbolted. Really gotta pull HARD. I had to bolt up the old handle and kick it. Make sure you use the bolts MGW gives you - do not re use the stock bolts.
doodad
very easy.
read the MGW directions it will be piece of cake. just take your time. i did in half an hour in my garage. directions are very clear!
spike0284
spike0284
Thank you. I have read a lot of comments and seems like this is the one to get.
Gary101386
Just a GT...
i 100% agree...
takes no time at all!
Flatliner
I'm kind of a big deal...
This is a easy DIY, follow instructions and take your time ;)
-=SVT=-
Gold Member
Hit it right on the nose with this post! It is easy with the exception of getting the old one off.:biggthump
Avoid getting any of the old sealant in the trans. Take your time cleaning off any sealant so you get a good fresh mating surface. As mentioned, it's a simple install.
I had to pull mine on and off half a dozen times due to a problem with the spring on the 1st gear side. The people at MGW were very good at customer service. They sent me replacement springs which didn't help and then a new shifter which resoved the problem. I'd highly recommend both the shifter and MGW.
Flatliner
PS The CobraBob gasket makes it painless for the new seal... ;)
nytebyte
Not Politically Correct
To get the old shifter off, grab the top of the base with a pair of vice-grips then pry it. It will pop right off E-Z, no problemo..
spike0284
spike0284
Well, I installed it today. No problem. So far, it feels great. I love it!!!
Thank you all for the input!
