Input shaft
Freebeer187
The Bolt Rounder
Feb 2, 2009
5,334
10
Schaumburg
This is an input shaft right?
I remember at one of the transmission shops the guy said that the stock input shafts had very little thread on them and would eventually shave.
He said the hardened ones they would heat treat them to "harden" them. Is this what u guys mean when you say hardened input shaft or are you talking about a different metal used or what?
Mike K
13,214
2,586
If that's a very antiquated looking torque converter then yes, that's an input shaft. There's no common denominator when it comes to failures unless you're looking at a specific transmission. On one transmission it might be the splines that sheer off and on another the shaft might just break clean in half.
On the W Bodies the splines generally don't fail. It's the shaft itself that fails, generally at it's thinnest point. The replacement shafts use a harder metal and thicker walls to prevent future breakage.
85,567
45,830
Joel
That looks to be a pump to me not a converter.
