Injector testing?
Fish
From the quiet street
40,573
7,974
Hanover Park
Fish
Is Casper's still around? I remember them doing it...
phat_ridegt
3,351
Ottawa
yeah it always depends on the impendence of the injector of course, but ohm all 8 out, and record the readings....you may have one that is way off then the rest....i dont have a spec, but they should all be within 5% or so id say....
pretty unlikely this will show you the results you are looking for since the problem (from what dtb described to me) isn't always there....but thats checking the resistance is the first step to diagnosing a bad injector
Pressure Ratio
20,479
12,276
Glen Ellyn
One 6 i think they do it. Ask for mark
8475939490
I would be calling the place that sold them to u. They are not that old.
A set of injectors can be off by a good amount. Especially when you are looking at larger injectors. 2% of a 24# injector isn't much. 2% of a 80# injector could add up. So unless the place you bought them from flow tests and matches them they can be off slightly.
Saying that I do not think that is dan's problem. It would be some thing that would be an issue all the time.
TURBOC1
Addict
Oct 23, 2007
781
21
Marengo,IL
true. but he does have a good idea to see if one inj isnt spraying right. cause talking with him on sat, he was saying the flat spot was at a small range of ms in the logs. but i dont know if the duty cyl was doing anything. (sorry for saying this dan) but it does sound like a fun problem to track down.
