in-line fuel pumps
ldyzluvdis06
Supercharged C5
Jacksonville, IL
how many people use them? can i use an in-line pump in conjunction to my pump in the tank? as like a secondary pump just in case?
if not i will be buying a prj pump at some point. but how necessary is the harness? is it hard to wire or something?
sorry to be a noob but i have yet to learn everything. :rollpicard:
utryd2
North Aurora
I have an inline walbro 255 new with mounting kit I will sell you for 100 if you want it.
shoot me a pm if so.
Eagle
Nemo me impune lacessit
Woodsticks, IL
You can use two pumps, but you don't get a 1:1 increase out of the 2nd pump. What are you trying to accomplish?
ldyzluvdis06
ldyzluvdis06
Supercharged C5
Jacksonville, IL
well i am having a fueling problem (at WOT and boost above 8#'s...it was fine for a couple weeks at like 15#) the fuel pressure drops down to like 37psi. i am not sure if it is the pump or the regulator. i ordered an adjustable regulator but it hasn't came in yet. but i bought my pump used so it could also be that. so i was just thinking about throwing an in-line pump on the car. :dunno: i figured it may pick up the slack that the other one has (if the pump is the problem)
hope that's not to confusing, i've had a few to drink :rollpicard:
Eagle
Woodsticks, IL
What pump will you be running? One pump should be able to handle your power levels I'd suspect.
ldyzluvdis06
ldyzluvdis06
Supercharged C5
Jacksonville, IL
a single pump could def. handle my power level. i just dont know of any good in-tank pumps besides one from prjperformance for $225 and i dont want to spend that much if i dont have to. i figured i could get a in-line one for a lot cheaper
Eagle
Woodsticks, IL
What about the Bosch pump? Or a walbro? Should only be about $100 pump.
DanJoy
The walbro 255 is commonly used in tank on 3800s. What size injectors are you using?
SRT41320
Lake in the Hills - IL
many options....
1) walbro 255 intank would be the easiest - for most cars its almost twice the flow and fits in stock tanks
2) walbro 255 intank to another 255 inline - budget builds use this setup a lot
3) walbro 255 intank to a Bosch 044 inline pump - pretty common among anybody looking to get a little more out of a 2 walbro 255s - little more pricey though, but still budget friendly
