I'll be doing a Compression test on Weds on the thing,
pcalert
New member
Mar 26, 2012
USA
Basically its a GT/V6 automatic eclipse, the timing belt is still in one piece, albeit it has hunks missing out of the back of it, and was certainly original (120K on the car)
It was being driven down the road and it made a loud/unpleasant sound from the engine and it died, was towed home.
Sounds un-happy when its being turned over, and the belt is visibly loose.
Anyone know if these motors are interference or not? and if-so, I assume a compression test would confirm the valves are toast? If not, what should I do to confirm?
bikrboy128
Some say.....
12,895
11,599
Wheaton
if it's a 3.0l ohc then you can count on the intake valves being bent.
slap a new timing belt on and see what happens. a compression test will confirm the valves junkness.
i had a stratus rt (same drivetrain) come in with a shredded timing belt from the crank pulley coming apart and through the timing cover. every intake valves was bent, exhaust were fine.
  • P
  • 1
  • 253
