BUILD IceCreamAssassin's Turbo Coprice goes to the dyno and makes some jam - 1000 WHP here we come
IceCreamAssassin
When I doubt, throttle out
TCG Blue
Jan 28, 2011
11,500
13,549
Cary
So this is just where you use liquid nails and a paint roller right?
Kind of curious were those the original heads and bolts? Find anything odd with breakaway torque during teardown?
How many beans ya give it to blowtorch em? what like 4 cylinders from the looks
Original heads, arp head studs, probably about 19psi on 93 instead of E85 which is probably my problem.
1quick
TCG Blue
Jan 29, 2008
25,626
20,936
38
coal city
It sat all winter with E85 in it so I was just running a tank of 93 to clean it all out to put fresh E in it before track day
I used to have a fitting rigged up to unhook the fuel line at the rail and run the pumps to drain the tank
IceCreamAssassin
TCG Blue
Jan 28, 2011
11,500
13,549
Cary
Solid idea for sure! Would be great for when switching back too so I don’t have to worry about driving till it’s as close to empty as can be before filling with E again.
1quick
TCG Blue
Jan 29, 2008
25,626
20,936
38
coal city
Except most in tank oe config pumps run really hot when the fuel level gets below a quarter tank....
I've never had a problem with quarter tank switch over as your fuel. Trims will easily adapt up to sixteen percent.... 2nd fill up I just reset the trims again and I'm good.
It takes like 5 minutes to drain the tank they don’t get that hot doing that a couple times a year
1quick
TCG Blue
Jan 29, 2008
25,626
20,936
38
coal city
No you're right. I'm thinking with return systems where the engine is heating the fuel returning to the canister. The pump will get awfully hot at the last bit of the tank
I experienced that in the mustang on a long trip almost didn’t make it home was so low in gas for shits I felt the tank and the fuel that was left in it was hot like 100+°
IceCreamAssassin
TCG Blue
Jan 28, 2011
11,500
13,549
Cary
I’m not worried about the fuel trim, just the ant the highest available E content for all the boosts
