I need Meth kit recommendations
utryd2
4,288
304
North Aurora
Alkycontrol has nice braided lines with their kits. I have a snow performance kit and it works great. Far easier to install than a alky kit and works great but comes with plastic lines. You can always buy braided lines if you went that route and wanted that. I use 100% meth and no issues.
Zack
4 Doors 4 Life
Mar 21, 2004
6,297
20
NW Indiana
Well, I went with Alky Control.
The kit will come in stages, based on where I mount the pump and tank.
Then I will have the lines made and finish it up.
My buddy has had an alky kit on his car for 3 years with no issue, which swayed my mind in that direction.
Thanks all.
greasy
36,946
29,069
[MENTION=4846]Zack[/MENTION]
I am curious how you are planning to run the meth?
Typically you want to run it pre-MAF so you can take advantage of the cooler temp readings. With the MAF sitting right after the filter on a positive displacement blower car it makes that more difficult. Are you going to split off the IAT sensor and run it after the TB? When I was talking to Rodney at AIS he was suggesting to run both pre and post MAF.
Zack
4 Doors 4 Life
Mar 21, 2004
6,297
20
NW Indiana
The only IAT on the car is post-blower....because roots car. :bigthumb:
rocket5979
Gearhead
Nov 15, 2005
6,576
18
Round Lake, IL
A few recommendations...
Pre-IATS? Yes! Pre-MAF? No. Always separate those two out and do it the right way; especially on a Ford hot-wire MAFS. It simply isn't a good idea to spray before the heated filament on the MAFS. Heat shock on such a thin wire can easily lead to breakage of the filament and failure of the entire sensor. There is no need to subject it to more abuse than necessary.
In a PD blower setup, the proper place for the IATS to be would be post-blower so it can feed accurate/actual intake temps to the ECU after the air charge has been heated up due to being compressed.
