I need a new wheel bearing. BP speed shop?
Freebeer187
The Bolt Rounder
Schaumburg
I got my tires rotated. The guy showed me how my front passenger wheel was not solid and moving very slightly. He said I need a new wheel bearing.
Maby someone here could help me with that (the good people at the BP speed shop)? I also need a new motor mount and a replacement oil pan gasket...
Anyone down?
Eagle
Nemo me impune lacessit
Woodsticks, IL
I need to do this too... and soon. It's starting to make noise... :noes:
ilikemtb999
I eat dirt
Denver, CO
Wheel bearing is very easy. You have a warm place to do it? If so I'm willing to help.
Freebeer187
The Bolt Rounder
Schaumburg
Cool man thanks for the help. Unfortunettly I do not.
I gotta make an appt with bikrboy. He's got a warm place and is good at this stuff :D
OffshoreDrilling
This is my safe space
Chicago
4 bolts and a plug. It's like 10 minutes tops
I did 2 wheel bearings on a Monte Carlo. Hollly fuck, they did not want to come off. Ended up drilling out 4 of the bolts, and taking an air chisel to the head of another one after I burnt up my drill bit.
ilikemtb999
I eat dirt
Denver, CO
Does timken make ac delco bearings? I know they make a ton of bearings.
i havent had any issues with the timken or skf bearings....IF the hub nut is properly tightened for the right preload....most failures i see of new parts are frm the axle nut being too tight/loose
10sec
LMK when this secret wheel bearing replacement meet is, i'm down. :noes:
Runtz52
Manhattan
