It's interesting even when it's brought up among 3800 guys. It can range from ZZP=god to "I bought a ZZP sticker one time and it ripped right off when I hit a tree at 50 mph. NEVER SHOP THERE!"I would imagine zzp to push the stuff with their name on it before anything. Also it's a bit interesting to watch what the ls guys have to say when zzp is brought up in a conversation lol
I bet you and a couple other 3800 people could make it happen with a stock ECM. Lolmaybe its time for a Freevalve 3800....
What a coincidence that you brought that up. Yesterday, I found some old forum posts which show somebody correcting this issue. https://www.grandprixforums.com/members-rides/89862-00-impala-ls-5-speed-and-supercharged-3.htmlThis thread has been pretty useful and timely for me haha
So the Rollmaster crank gear still needs to be machined to match the crank chamfer? I thought I had heard that they solved that issue but can't find anything to confirm yet.
I'm thinking this would be a good opportunity to buy a mini-lathe.
My understanding is that the gears are aligned and will actually work fine without machining. However, it requires the thin cover and thick gaskets. If you only machine the crank gear chamfer, your chain will wear out quickly from the gears being misaligned. The cam gear has to be shaved down in order to be at the same distance from the block as the crank gear again. This is where I get a little weary about this mod. This set is proven to work fine despite the crappy machining. Fixing it correctly is worth the effort, but fixing it wrong can cost you an engine.Good info then for sure, I'll be sure to send mine off once it arrives then. Sounds like I won't have to use the machined oil pump cover too so that's a win in my book. My bolts would not come loose when I tried to take them off last time.
What is going on in that thread where they're machining the cam gear?
