30$ seems really reasonable to have it done right.
So by this logic anything over a .540 would be a waste anyway?Whoops, 1.6 would be even higher lift difference. May be thinking Ferd or something.
You'd be at .646 and 0.6365 with 1.9s and that cam. If you multiply those #s times .85 you'd end up with .5491 and .541 as the desired peak flow lift. Yeah, you're not gonna get even close with these heads based off ported #s I've seen. Definitely doesn't seem worth the headache. If you had heads that flowed near .55 I'd give it consideration but these just aren't those heads.
