Yeah, but I'm not using them with the cam.don't you have 1.9 rockers though? That is why you check clearances.
Those are for sale on marketplace by the way. Shameless plug.
So, what your saying is make sure the rockers arent shoving the retainers into the seals then?
I guess I'm not quite sure how much added lift the 1.9s give without doing some research but this could be probably be valuable information to someone looking at cam swaps.
Lol I like the attitude, but I don't think there's much point without putting bigger valves in. I might be wrong about that though. Maybe Yates will come out with his "max effort" aluminum heads soon. $$$$Get the clearance do both lol.
sotock rated lift/stock ratio*new ratio. These heads seem to stall at .5 looking quickly but you really want lift to be near peak flow lift/.85 due to the cam not spending a lot of time at peak lift.
Also after looking up stock cam specs both intake and exhaust lobe are .413. Divide that by the stock ratio of 6 you get .0688, multiply by 9 and your at .6194
So, either my maths way off or we should be machining valve guides for 1.9s?
Isn't stock ratio at 1.6 tho? That would make more sense and would put it at .490 with 1.7 it'd be at .461. So my math was definitely off
Missh it's really easy if you use an old valve in each guide as you go along you can use the old valve and the head spaced off of your workbench as a guide for stopping you at the correct depth but then you just Chuck a half inch drill bit in your drill and you drill away the top of the guide tell it stops on the end of the old valve repeat for the rest of them and then clean up with a small little 3-inch roloc die grinder read redo the chamfer around the outside for the seal install and walleye you have .1 inch more cam lift clearance
So, pull the springs, space the old valve .1 under the top of the guide and drill down til you hit the valve then clean it up with the die grinder? That seems fairly simple but you'd have to be fairly precision when finding a way to space the head off your bench to make it work. But say you left the head on the bench with the valves off and used your calipers to measure distance to your bench and took .1 off that? You'd accomplish the same?Missh it's really easy if you use an old valve in each guide as you go along you can use the old valve and the head spaced off of your workbench as a guide for stopping you at the correct depth but then you just Chuck a half inch drill bit in your drill and you drill away the top of the guide tell it stops on the end of the old valve repeat for the rest of them and then clean up with a small little 3-inch roloc die grinder read redo the chamfer around the outside for the seal install and walleye you have .1 inch more cam lift clearance
This seems sketch even for me ?Lol. I've even see people take an angle grinder to them.
