I’m working on getting pricing together for more standard items, starting with humidifiers.
Pricing: $625
What does this include?
-AprilAire model 500M or 600M bypass style humidifier (depending on home size)
-Cut supply plenum to accept humidifier base.
-Route sheet metal duct from humidifier to the furnace return air drop.
-Seal all humidifier duct and fittings for air leaks.
-Route 1/4” copper water feed from nearby water line to humidifier solenoid using supplied saddle valve. (Extra charge beyond 20’ of copper)
-Plumb drain from humidifier to existing condensate piping, modifying as necessary.
-Install and wire humidistat on return duct, or, integrate with current thermostat/controls if supported.
-Wire controls to operate humidifier on heat call only.
-Commission humidifier and verify proper operation.
-Instruct customer on operation, disabling unit for summer and basic maintenance required.
EXTRAS:
Modify plumbing and install 1/4 turn angle stop valve. Why? Saddle valves tend to leak over time and may not offer positive shutoff of water feed when desired.
$75 installed, all labor and material included
NuCalgon HumidiPro humidifier treatment filter.
Inhibits scale producing minerals from your water supply to increase the humidifier pad life.
$50 installed, all labor and material included
What do I need from you?
Send me a PM, text (630) 981-4505 or email [email protected], along with photos of all accessible sides of your furnace and distance to your nearest water hookup.
Pricing: $625
EXTRAS:
