How do you drive your manual vehicle?
How do you drive your manual?
  • Total voters
    46
Primalzer
How do you drive your manual equipped vehicle? Jalopnik post got me thinking, and I like to drive, if possible mostly clutch-less, although I have been getting lazy as of late and have been using my clutch more and more.
greasy
LTTR BOX
The Litter Box
I am curious as to how you drive a true manual car without the clutch :confused:
OffshoreDrilling
This is my safe space
Chicago
i like my autotragic. A nice shifting built auto with a converter is pretty fun.
Angus
Bentonville, Arkansas
You need it really only from a dead stop. The other gears can be rev-matched and it'll go right into gear.
I use the clutch all the time though. Driving clutch-less, there's a hard learning curve for your transmission...
greasy
LTTR BOX
The Litter Box
Gotcha, I always used my clutch. I rev-matched still using the clutch
when changing gears, but it was purely to make the shifts seem seamless.
Angus
Yeah that's what I try to do too b/c my new clutch setup is almost all or nothing when grabbing. If you're in the wrong rpm's when shifting, it's kinda unforgiving...
THEHKP7M13
4106
THE 60402, LIKE THE O.C., ONLY BETTER
Don't forget the term "power shifting". At least that is what the porter at the dealship said he could do with a 5.0 Mustang on the wholesale lot back in 1996. Needless to say his "powershifting" resulted in a transmission failure!!!
espresso8097
Las Vegas
Clutch every time, sometimes between third, fourth, and fifth I will match the RPMs and not use the clutch. Or will pull it out of gear and into neutral without the clutch, but go back into gear with the clutch.
P
Primalzer
This...it is actually pretty easy once you learn how. Just slip it out of gear and hold firm pressure on the gear you want when the rpms are matched it will automatically slide into gear with no grinding or fuss.
El Presidente
All clutch. Im not paul walker
E
State of Confusion
I clutch all the time.
I have a fairly hard clutch pedal so i tried shifting without but the RPMs drop really fast and gas pedal is very touchy. My left calf gets a hell of a workout
SinisterSHO
Tame Racing Driver
clutch every gear, sometimes i will put it in neutral without the clutch, but not often.
b00ya
AHHHH!!
Anna, TX
clutchless on the last manual car I had, next one will be same thing cuz im just too lazy to press clutch in every time.
syP
Not Banned
Downers Grove, Illinois
clutch ALL the time up shifting.. and never when taking it out of gear... (Ie.. coasting to a stop).. i blip the throttle and pull it out of gear.
CrunkMaro
DurkaDurkaTerrorist
wow there are some fools on this site.
i object to the term "slushbox" especially since a built auto will outperform a built manual every time where it matters. then again..maybe some of you guys are into fast and the furious style shifting where you somehow have 500 gears.
i drove my 79 hard...really hard...harder than most of you would ever imagine putting your car through. 6700 rpm shifts full on the t56. i was young and stupid and i regret it. nothing like killing a twin disc clutch in less than 1k miles.
i'll take my "slushbox" anyday now.
El Presidente
Its not always about "all out performance" or "fast and the furious". To a lot people, driving a manual is much more engrossing and enjoyable than an auto.
Ron Vogel
Bolingbrook
Autos are faster, the ONLY advantage a manual car has is for road racing and that's not even that much.
I used to be manual guy, but after enduring it for 5 years...looking back my previous hot rod had a nice built AT...and it was more fun.
CrunkMaro
DurkaDurkaTerrorist
It is for me. built auto and giant converter on my last DD. i don't mess around with cutesy wootsy "gas clutch shift clutch gas repeat " I guess for some people it IS fun...if i had a slow car i'd want it to feel as quick as possible as well. Lower the bitch, stiff springs, stage 3+ clutch on a stock motor stock trans stock diff just for that "hells ya" feel.
I like you. even though your avatar creeps me out a bit.
ilikemtb999
I eat dirt
Denver, CO
This thread says how do you drive your manual car....so why you in here? Just sounds like you don't know how to drive a car :mamoru:
utryd2
North Aurora
I always use the clutch in the vette.
Sure autos are faster at the dragstrip no question, but for me I like the control I have with a manual and it is a ton more fun to drive my car in a manual then it would be auto.
I had an auto in my 71 chevelle with a shiftkit. It was fun but isnt the same to me. Keep in mind Im not a hardcore track guy either.
P
Primalzer
It takes a lot more talent to drive a manual fast without blowing up a clutch and transmission than to just throw a converter and a built tranny on the car. And I like being able to row my own gears, my DD is not a race car and it by no means is fast and I don't want it to be, I want it to be reliable. When I drive an auto I get disconnected with the car and I lose the driving experience. To each his own.
And i stick by my term of slushbox because 99.99% of autos out there ARE slushboxes.
