This is on pump gas?337whp/363wtq here with the XP
-XP cam
-Gen V w/ 2.8”
-S2IC
-Pacesetters
Biggest thing holding me back at this point is probably my stock AF heads. But I have no intention of making an effort to change this.
How? It’s going the wrong direction. You’re talking about the old 60’s and 70’s FWD transmissions with no overdrive, correct?From the looks of it, the 80e isn't the answer either. It's better than the 65e at 500hp, but at 600+, they don't seem to hold.
The th425 is our only hope.
what do you think is holding you back? 330 is good for what in these cars? Mid 12’s?
Agreed. I think the 4T80 is also still in its infancy. I think their will be more progress made on them.I think longitude RWD is a more obvious answer if 4T65s are your problem. I agree that the 4T80e developments seem a bit disappointing.
Just saw another thread on FB about the 80E failure. Apparently the transmission at the valve body face warps causing a leak with the VB…Agreed. I think the 4T80 is also still in its infancy. I think their will be more progress made on them.
From what I understand, the torque flexes the case, causing the valvebody to leak internally. At 500hp, it will probably last forever though. That's about when people seem to get really tired of the 65e, so the 80e is a good solution for 500hp cars, but it's not capable of being the 600hp solution we are after.How? It’s going the wrong direction. You’re talking about the old 60’s and 70’s FWD transmissions with no overdrive, correct?
Yup, that's what I was seeing. I don't understand how the ls4 guys don't see this problem, but both the high hp 3800 guys did.Just saw another thread on FB about the 80E failure. Apparently the transmission at the valve body face warps causing a leak with the VB…
That’s crazy power!
He said he was doing 700+ for many runs
RPM??Yup, that's what I was seeing. I don't understand how the ls4 guys don't see this problem, but both the high hp 3800 guys did.
Could be. Mounting is basically the same on both engines.RPM??
I’m going to agree with you 100%. I’ve been working on cars since the 90’s day in day out and I’ve never seen a trans “warp” from TQ. They break! Window! Snap parts or send shrapnel throughout.He is claiming that the channel plate is badly warped. The transmission builder is telling him it's from the torque.
But, I think it was also a high mileage transmission with an unknown past.
