HELP!
john99gtp
lockport
I keep getting this code comming up after a few weeks P0420 Catalyst System Efficiency Below Threshold (Bank 1). What hould I do?
BigJermGTP
Montgomery
[snapback]140842[/snapback]​
I'm assuming it's your catalitic converter. It may be clogged.
Try a new rear O2 sensor. If it still comes up you may have to replace the cat or delete it. If you get a straight pipe instead of the cat you need to tune it out or get a rear O2 simulator.
Just a guess on my part, just giving you some ideas of some things to check.
Xtant12
Originally posted by BigJermGTP+Sep 27 2006, 07:47 PM-->
<!--QuoteBegin-john99gtp
[snapback]140854[/snapback]​
[/b]
He is right.. My cat was F%#ked so I just cut it out completely.. I got that code a few times.. When they cut my cat out it was clogged with Gunk... Then I tuned the codes out and no problems.. I was going to do the cat anyways, that just gave me my push. ;) ...
