Help!! Rear main seal question
stupidgenius
Active member
while i had my trans down for replacing my clutch i thought i might as well replace the rear main seal. i took the old seal out using a screw to grab it then pull it out.
the new seal that autozone gave me does not match what i removed from the block... i am wondering if the old seal broke in half. i'd go ahead and try to remove the rest of what appears to be the seal around the crank, but i dont want to screw into something that's not the rear main seal.
here is a picture of what my crank looks like right now. is part of the old seal still stuck in it, or did i get the wrong seal from autozone?
crankshaft area
new seal on left, old on right
CREJoe
Chassis Builder
It looks like you didn't get all of the old one out.
Bullitt-1469-
The old one is still in there take the rear main cover off and replace it, its held on by two bolts under the oil pan and six on the block...
Frodo
You definately did not get all of the old seal out, if you have a pick of some sort you could try using that get the remainding part out, just be careful. but the best option is using a seal puller
stupidgenius
stupidgenius
Active member
yep that was it. i figured it out after checking out a chilton book, but you were exactly right. thanks!
