3800 Help please with my whipple ax140 engine build
32,650
16,127
We're so screwed....well the l26 shorty will be shortly.....
jdredd
Addict
Jan 29, 2014
734
298
I still got the complete cog setup collecting dust in basement..... to bad never worked out right. Alignment issues I guess was causing it to shread belts in 100-200 miles if that long.
Maybe one day revisit it, when I decide I need to hate life more than usual....
But to be honest, the 10 rib setup, gates rpm belt, and tweak to the idler setup and tensioner, pushing 27psi with hardly any slip at all now... holds very steady.
So I can't find a good reason why to go back other than for clout and the sound of it.
Picture doesn't show, but the cog blower pully, whipple snout broke off in it... oops.
jdredd
Addict
Jan 29, 2014
734
298
Sounds like just going to a 10 rib is the way to go.
So far with the RPM belt, man it holds well. With the green back belts, those would stretch horribly bad after just one pass at the track.. enough to where it was basically ruined.
As mentioned in other post, ive had same belt for 4-5 years now... green back 10 rib, replacing all the time, and basically 1 pass per belt.
Regular gates black belt, didn't hold up much better.
The RPM being designed for superchargers, has been a god send.
I don't drive car balls to wall all the time.... but even so, the old green belts would wear out after a few weeks of normal / little spirited driving, not even WOT runs...
sktchy
7,765
12,055
Idk why everybody likes those green ones. They're ugly, expensive and they suck on a stock engine. Must be a b00m3r thing like felpro gaskets.
GTPpower
6,358
9,767
Nebraska
I wish they had more variety of sizes. I might need to figure out some kind of adjustable tensioner.
jdredd
Addict
Jan 29, 2014
734
298
I think might have posted this in other thread, but I had my blower pulley coated in this also.
I thought about having all the metal ones done in this, but never did as things worked out well in the end.
Reactions: GTPpower
GTPpower
6,358
9,767
Nebraska
Does it make the pulley rougher?
jdredd
Addict
Jan 29, 2014
734
298
Yes. It does cause some dusting for a while but seemed the belt settled down on that mess.
I am 5 years now on this one single belt. It has not swiss cheesed it up yet to point I need to replace it. Not frayed or anything. Still looks pretty good.
Still has plenty of grip and virtually no stretch. I am sure it has stretched and lost grip to some degree after all these years....
but I assume its less than 5% of the stretch after all these years than the green back belt after 1 full pass at the track which made it useless.
I did mention, I don't drive like I stole it every time im behind the wheel.... so if you are a lead foot, maybe different results :)
Reactions: GTPpower
