When I bought this Whipple kit, it came with lots of extra parts. Some I'll use, most will just get sold.
However, I'm looking for advice on the engine. I know a stock bottom end is likely strong enough, but it is also my opinion that a 500hp supercharged setup is harder on the bottom end than a 800hp turbo setup. With an expensive blower, intercooler, and heads, I would rather not risk it.
I have a set of aluminum heads I'm planning to use, but I'm not sure what headgaskets to go with. ?
As for the bottom end, I have a l32 engine that needs a piston, and probably a hone. My thoughts are to use the stock l32 rods and machine the rods for arp bolts. Bore the block .020" over, align hone the mains, do James' oiling mods, arp main studs, but what about pistons? I have a new set of JE diamond 8.1:1 pistons, but my gut tells me I should really bump the compression since the Whipple produces so much heat.
Lastly, how about the cam? Should I stick with the xpz, or go to thr is3 or is4, or maybe go with something completely different?
