Help needed: 2000 Taurass DOHC
RICH17
Dr. Pussy Slayer, MD
26,707
1,992
The 007
Adam Rich
Well my friend Sarah has been having all sorts of issues with this car. She has replaced the IAC and TPS but still has intermitent running issues. And has a lot of codes. She's been getting terrible mileage and the car wants to die periodically. the codes that are on it are...
P1120
P0122
P1121
P0190
P0191
P1237
P0422
Anyone know anything about this? I've been googling like crazy but havent found anything yet that is just like hers. I know these cars are POS but it has to last her for a little while. Any help is appreciated
Dasfinc
Ready for the EVlution
Sep 28, 2007
20,919
1,321
Wheaton, IL
Aaaaaand now I don't want to help.....
The DOHC taurus motor is a Duratech family motor, and is an extremely smooth and typically well built motor.
The issues that generation of Taurii are known for are:
Cracking springs
Subframe bushings
Fairly weak Transmissions
Not really known for a slew of motor issues. How Long has it had issues? Any other recent repairs?
What does each code mean?
hellraiser319
Hellraising since 1986
May 17, 2010
1,323
West Bend, WI
Only thing I can come up with, you have failures of multiple monitoring systems, my first instinct would be to check the reference voltage going to the MAF, TPS, etc etc, make sure its a healthy 5v. Also, is the signal actually getting to the PCM, or is there a short/broken wire or 3, causing problems for everything else... I think best bet would be to grab a DMM, start checking stuff both at the sensor in question and at the pcm...
RICH17
26,707
1,992
The 007
Adam Rich
Cracking springs
Subframe bushings
Haha Sorry Das. I just have a hate/hate relationship with Ford lately. I know these are a good motor when running right. But theres so many sinsors and BS that just pisses me off and makes me love the 3800 even more.
RICH17
26,707
1,992
The 007
Adam Rich
I know the car sat for a while. And a rodent got into some of the wiring and chewed it up. It was fixed at a "shop" but looking at the work it seems sketchy. I know it throws a TPS code right away after I erase everything so I might have to check the wiring.
Is the engine harness replacable or does it go through the whole car and need alot of cutting and splicing?
And I know the stuff this shop replaced is with the wrong gauge wire. Would that effect the voltage readings enough to have these problems?
01Cobra
Johnny Cobra
May 3, 2006
8,686
3,207
Cracking springs
Subframe bushings
You forgot about the excessive rusting.
hellraiser319
May 17, 2010
1,323
West Bend, WI
There may be a main junction somewhere for everything in the engine compartment, hit a junkyard, grab a "new" harness, swap it in...
BrianG
Big Dick Team Octane
Oct 5, 2008
5,715
74
Brian G
There really is a lot of weird stuff going on with this car. The TPS was changed within the last year, but when I was scanning it, at full pedal depression, the scanner was only reading 70% throttle. At least one of the codes above is a TPS code. The other wierd thing about the TPS is that I picked up a new one from NAPA and the notches on the inside of the sensor don't even match up with the key on the end of the valve plate shaft. Not sure WTF is going on there. She swears that it was an animal that got into the engine bay, but it really does look more like the serpentine belt blew and shredded the heat blanket under the hood right above the belt area.
BrianG
Oct 5, 2008
5,715
74
Brian G
P0122 - Throttle Position Sensor/Switch A Circuit Low Input
P0190 - Fuel Rail Pressure Sensor Circuit Malfunction
P0191 - Fuel Rail Pressure Sensor Circuit Range/Performance
P0422 - Main Catalyst Efficiency Below Threshold (Bank 1)
P1120 - Throttle Position Sensor out of range
P1121 - Throttle Position Sensor Inconsistent with Mass Air Flow Sensor
P1237 - Fuel Pump Secondary circuit fault
P1120 and P1121 would be explained by the 70% at full throttle. Maybe low input (code 0122) is causing low output??
I should also mention that I verified the TPS 70% max output with a screwdriver in the back of the sensor, so its not an issue that the pedal isn't getting full depression.
