help me, vac leak. (attn: Vogel/James)
Harbor Master
ive been working on my moms car for 2 days now...
i did LIM gaskets... and a new upper intake manifold gasket...
i have a vac leak.
when i spray carb cleaner at the throttle body area, around the egr tube, the car bogs even more and dies occasionally. ive taken it apart and put it back together about 4 times now today alone.
the one thing i am thinking... that i havent played with yet... is the egr tube...
is the egr tube supposed to protrude all the way down into the lower intake manifold... or is it supposed to stop at the gasket...
thanks in advance.
Harbor Master
regal ls. l36 (3800 n/a)
James
Get the gasket mating surfaces cleaner or use some gasket dressing. At this point just use a thin layer of RTV or silicone.
Why are you changing them in the first place?
Harbor Master
im thinking that its supposed to sit down in it .
the egr flows up through the throttle body... so basically right now there is a restriction which allows it to flow around.
sooo.. yeah... give me like 2 hours... ill be back with what happened...
El Presidente
yea, was coming to post more or less the same thing
Fish
From the mean streets....
Chiraq
Up through the TB?? On my old GT the tube went into the LIM just under the TB. I had a hard time with my EGR after the headers so I just removed it and blocked it off. I know the tube is supposed to go inside the the worthless plastic piece bolts onto the LIM.
L36/67 LIM gaskets fail anywhere between 50-70K miles. In 04 when they did the L32/26 upgrades, they got metal gaskets that seem alot better then their predecessors. I hope thats what you used KJ.
Now that I think of it, my old GT had 142K on the clock and I never did LIM gaskets. LOL.
Harbor Master
i was saying more as a direction than actual path... for the flow..
PANDA
FRG
I just got my LIM gaskets and a few other things done to my car, the mechanic used the OEM GM aluminum gaskets. Sorry I cant help though, im sure Ron Vogel or James can post up some useful information.
Harbor Master
yeah l67 is different.. and those did not present a problem to me.
Ron Vogel
Bolingbrook
I can almost guarantee it's the EGR tube. They get pretty brittle after time, and r&r'ing the LIM gaskets means you had to disturb it. Sometimes you can grab around the tube itself to hear a leak. At least to rule it out try plugging the EGR hole where the tube goes in at the LIM. It's a cheap enough part that it's not too bad to replace.
LeddZepp8687
naperville, IL
If you changed the gaskets, Im with vogel. Those tubes cant last forever, The joints are probably leaking. If it was a solid tube there really wouldnt be any problems but because its flexible and can move it id just one more thing to break. I just looked on Carquest and Napa and neither one of them carry the tube itself.
The gaskets notoriously fail, So much that we stock them for the Three point one, Four and Eight.
Harbor Master
well... finally i just said eff it... and went to autozone... and picked up an entire new upper intake plenum because i figured this one just had to be warped or something goofy weird or some shit...
annnd... new one game with new gasket, new pcv stuff, new brake booster connector doohicky new throttle body gasket rubber thing new injector o rings new egr tube thing... basically a whole buncha stuff...
and i drove it back to my moms 20 minutes ago! thank goodness that is over.
LeddZepp8687
naperville, IL
SO I guess it was the manifold?
Harbor Master
i think it was a combo the 150k mile old manifold/egr tube
Fish
Chiraq
Yeah, the plastic plenum is a PITA as well. I know a few NA L36ers like to swap to the L26 aluminum plenum.
Euro
GM or Nothing
Roselle
Agreed. When my LIM went bad a few weeks ago I went to the aluminum re-inforced plenum.
Fish
Chiraq
Thats the thing. I saw alot of problems the L36 had, I changed almost nothing cause it didnt need to be. LOL. The LIM gaskets are stock. Plenum is stock. Alternator stock. Water pump stock. Trans stock. Had 142K on the clock when I saw her leave.
I think Dan should send the car to GM and say "HEY!! Make cars like this one." Then again, no more 3800. :(
Euro
GM or Nothing
Roselle
You had some good luck with your GT!!! with only 61k I've already done the alternator, lim gasket, and plenum. I'm waiting for the trans to grenade so I can still catch it under the warranty!!
Fish
Chiraq
I know alot of people change alternators right away when they buy a used car. They are a real joker. Never know when they will be played out. My GT was still kicking at 142K. My friends GTP had a stock alternator go at 118K. Ive seen alternators go at 30K. Its all in the luck of the dice.
Euro
GM or Nothing
Roselle
Yeah, I had to replace mine because it was charged at 42amps :rofl: Where as the new one was 105...phew lots better!
smug
Cedar Lake, IN
Fish, well the old GT shall be hitting 150K very soon and all is well, knock on wood lol. As said before stock LIM gaskets, trans, water pump, alternator, and a hole bunch of other shit. lol
