Check owners manual about trans fluid change. My Fusion required trans fluid change every 30k miles. It was real easy to change because no filter. Drain plug and fill 5 quarts.
Phew, glad you didn't go with a CC. The TSI engines in those things are abhorrent maintenance-wise. And I'm a huge VW nut. Had a 2010 Passat for a while with the TSI, traded it in after a laundry list of problems came up at about 75k miles and the repair shop was literally out of ideas as to how to fix the intermittent bad misfire it had.
Tune it, the fun factor increases quite well [emoji16]
No, but I had a Focus ST so same/similar drivetrain. You can do a simple accessport with off the shelf tune or have someone tune you. Nothing really else required unless you wanted to unleash a little more.do you have one? i haven't looked into any performance at all. but i may consider a tune if it's affordable and doesn't require any other mods.
