Looks like this is Bob cooks car. I'm pretty tempted to throw a bid on it.
Online Storage Auction in Kissimmee, FL | StorageTreasures.com
Storagetreasures.com | Auction #887397
www.storagetreasures.com
it went 8's back in the day afaik
i think nhra certified chassis setup from back in the day.
What’s the significance of that car?
Badass
WORLD RECORD HOLDER
1999 FWD GRAND PRIX
ET: 8.902 - quickest 3800 FWD of all time
MPH: 159.10 - fastest 3800 FWD or RWD of all time
60’ 1.308 - quickest 3800 FWD of all time
CHASSIS:
B&R RACING CUSTOM PARTS:
Certified Chrome Moly Tube Chassis (to 8.50 seconds)
Chrome Moly Tubular Control Arms
Coil-over Struts
Straight Rear Axle
Wilwood 4-piston front brakes
Aluminum Interior
Chrome Moly 1 ¼ “ Wheelie Bars w/ aluminum rod-ends
Aluminum Coil-over Shocks
Line Lock
INTENSE-Racing Carbon Fiber Hood (one of only six ever produced)
Weld Wheels 15x10 & 15x3
M/T 29.5 x 10.5w Tires (20 passes)
Simpson Parachute
Auto-Meter Gauges
B&M Shifter
Optima Battery
ENGINE & TRANS
INTENSE-Racing RACE ENGINE
INTENSE-Racing 8.5:1 Race Short-Block
INTENSE-Racing Stage 4 CNC Cylinder Heads
INTENSE-Racing Stage 4 Turbo Cam
INTENSE-Racing Ported Lower Intake Manifold
Harland Sharp Roller Rockers
INTENSE Custom Dyno Tuned PCM
B&R RACING
Custom Upper Intake Manifold
1 5/8” Stainless Headers
76 mm Precision Turbo (GT42-76R-BB)
Precision Turbo Liquid to Air Intercooler
60mm HKS Wastegate
Multi-Stage Boost Controller
MSD DIS-6 Ignition System
AEM Injector Driver
Precision Turbo 95lb. Injectors
Weldon 2025 Fuel Pump
50 Shot NOS
LS1 Throttle Body
LT1 MAF Sensor
ATI Turbo Balancer
Meziere Electric Water Pump
INTENSE RACING TRANSMISSIONS (one in car, plus a complete spare with identical components)
GM Racing Case
GM Racing Input Shaft
GM Racing Gears and Drive Chain (3.52:1 final drive)
INTENSE Third Gen LSD
Z-Pak Clutches
ATI TCR-3500 Race Converter
This is the 8.94 run
Car will be sold turn key $25,000 or Best offer Bob Cook
I'm sure the chassis is still all there. All that would be welded in and wouldn't really make sense to remove. You can see the cage in the pics if you look close.
It was chassis certified to 8.50.
there are ways. just takes time.
