Heavily Modded Blue '98 GTP Pace for sale.
13SecPaceCar
Hartford, Wi
As is, should run nicely into the 12's.
Engine/Performance Modications
Comp Cams XP Cam
Comp Cams 105# Valvesprings
Comp Cams Valvespring Retainers
The Other Guys (TOG) Headers
RT Downpipe
No Cat
3" Catback
Dynomax 3"x24" Bullet Resonator & 2.5" Ultra Flow Mufflers
Mini AFC 2.2
Adjustable Timing Contro Modulel
ZZPerformance Modular Pulley System (3.2")
Auto Trans Design Shift Kit
Transmission, Performance/Race Rebuild
3.69 Final Drive (up from 2.93)
3000 stall Torque Convertor
Custom Tuned Digital Horsepower Inc. Powertrain Control Module
Stock Replacement GM Wires
'U-Bend' Replacement
Auto Lite 104 Spark Plugs (have 103s in back seat)
Boost Bypass Advance
CAI
180 Degree Thermostat
9'' K&N
Suspension/Wheel Modifications
17x8 24mm Torque Thrust D Knockoffs aka Bullitt Wheels
P245/45ZR17 Kumho Ecsta Supra Tires
Spring Tech 1.6'' Performance Lowering Springs
GM Performance Parts Heavy Duty Front Sway Bar
GM Performance Parts Heavy Duty Rear Sway Bar
GM Performance Parts Tubular Trailing Arms
GM Performance Parts Rear Strut Tower Brace
GM Performance Parts Front Strut Tower Brace
GM Performance Parts 12" Front Brake upgrade
Exterior Modifications
Sequential Taillights
PFYC F1 Style Hood
2004 GTO Quicksilver Metallic Painted Lower Fascias.
"Real" Pace Car Windshield and Rocker Panel Decals
Cleared Factory Taillights w. LEDs
Reflective Silver Front PONTIAC Inlay
Reflective Med. Blue Rear PONTIAC Inlay
Reflective Silver Supercharged Decal
PFYC Clear Corners - Parking Lamps
Pilot "Cyber White" Navigator Fogs
VT GTP Grilles
SLP Gen I "GTX" Spoiler
Removed Headlamp Diffusers
Sylvania Silverstar - Headlights
Reflective Arrowhead - White
High Gloss Bright Blue Brake Calipers
Interior Modifications
Lotek 3-Gauge A-Pillar Pod
Autometer Sport Comp Boost Gauge
Autometer Sport Comp Voltmeter Gauge
Autometer Sport Comp Oil Pressure Gauge
Miscellaneous Modifications
Goodyear Gatorback Belts
Ractive "Oval" Stainless Steel Tips
1999 Grand Prix GTP DIC
1999 Grand Prix GTP Red Display HVAC Module
"Hyperflash" Fix
High Beams/Fogs On Mod
pics:
http://www.nconnect.net/~briones/big.1jpg
http://www.nconnect.net/~briones/big.2jpg
http://www.nconnect.net/~briones/big.3jpg
http://www.nconnect.net/~briones/big.4jpg
http://www.nconnect.net/~briones/big.5jpg
http://www.nconnect.net/~briones/big.6jpg
http://www.nconnect.net/~briones/big.7jpg
http://www.nconnect.net/~briones/big.8jpg
http://www.nconnect.net/~briones/big.9jpg
http://www.nconnect.net/~briones/big.10jpg
http://www.nconnect.net/~briones/big.11jpg
the only things worth trying to demod are:
SLP Spoiler
F1 Hood
Bullitt Wheels
Cleared Tails
Mini-AFC
everything else won't be easy to get off. I'm having problems w/ a daily driver, that's also my toy, that's modded far beyond stock.
The car is back at the trans shop, it appears it likely snapped the input shaft again.
car has 107k, 4k on the trans, 6k on the cam
has new tires (will replace the bald slicks) exterior isn't perfect, there are stratches and chips here and there, but there are no dents/dings. a scuff near the right front foglight.
interior is perfect, except a small tear in the dr. side seat. been totally maintenance free, I just replaced the dr. side outer tie rod end on friday, when I flipped the sway bar for more DP clearance.
has so much power that WOT and traction in 1st gear are laughable.
pulls like a train, and I've had it up to 152, and it had plenty of balls left, I however didn't have enough balls to push it any faster.
brakes are recent, just touched up the paint on the calipers on friday.
it's already pre-wired for an aftermarket stereo. I will include the deck thats already in it. A Pioneer DEH-P6500
it's # 1321/1500 and 1/200 with a factory sunroof.
I have over 5k into the car just this year for mods, and therefore am starting off at 10k or best offer, I'm going to go find myself a new GTO to toy with, and will sadly be parting with my baby.
THIS IS FOR REAL GUYS, I NEED HER GONE
bigsammoe
Gurnee
if ur wiling to part let me know
id just want 180 T and cam
i have a IMP so not all are gonna fit
beyerch
umm helloooo hood and spoiler .... and front license plate cover ??? :-0
superchargedgp
[snapback]98182[/snapback]​
NO MODS FOR YOU :lolsign:
redgt03
Peoria, il
how much for the hood and spoiler...I am in Peoria, IL...so we could met up!!!!!
phat_ridegt
Ottawa
how much for the whole car as-is...you are getting the trans fixed...or no?
Fish
From the mean streets....
Chiraq
mybluegtp
Burbank
Dan just drive it over to my house and leave the keys. You know i will take care of it and you need nothing in return. :D
