3800 Header install advice
gtphale
1,578
Scott when you goto bend the dipstick out don't pull the tube out leave it bolted up. A lot of guys make the mistake of pulling the tube and bending it. Well then they have no idea where to bend it. Get the headers in then put a rachet in the hole of the tube and bend it where you need it to be.
Also in order to make the back header easier to get to use a strap and pull the motor forward will give you and extra 6 inches to work.
Hope that helps Steve
Jul 9, 2008
27
[snapback]69486[/snapback]​
Steve, thanks for the pointers, this is my first header install, and I want to make sure I'm prepared for anything. :D
Scott
gtphale
1,578
just put alot of time aside for it. First time will probably take you about 5 hours. Start soaking the bolts and nuts in pb blaster now. It will help you out alot. Pull the heat shield off of the cross over by the rear manifold there are two bolts there that will need to be soaked they usually just break off. So make sure your using a 1/2 drive on it.
