has any1 ever??????
FuelSlut
FK RED STAR
Nov 9, 2005
1,969
sonicblue2003 said:
on the pass side the stud is fixed to the heder. want to knoww if its pressed in or screwed in.
its screwed in. generally when you change the factory x pipe you sould replace the studs with longer ones depending on the fit of the x pipe. napa carries them, advance auto also. they r like $7 if I remember correctly.
FirstWorldProblems
70,749
81,399
Crown point, IN
FuelSlut
FK RED STAR
Nov 9, 2005
1,969
N20GT said:
The studs screw in and are IMPOSSIBLE to get out it seems. I fought with mine all day yesterday. I have a thread going too, check out the suggestions/pics. Not sure if mine is the same design as yours, but if it is ur in for alot of cussing and wrench throwing.
http://www.chicagosvt.com/forums/showthread.php3?p=258440#post258440
How did you try to remove them? What I did was I screwed the nut back on the stud as tight as I could and then I broke it loose. But then again my car only had like 10k on it when i did it so it wasnt all rusted on completly. I feel your pain though man good luck keep wrenchin.
