-Headstuds
-4" Turboback Exhaust
-Edge EGT Probe
-Mishimoto Coolant Filter
-Valvecover Gaskets
-Rear Main Seal
-Updated Oil Cooler
-Rear Cover Gasket
-Updated Turbo Feed Line
-Rocker Box Gasket
-Injector O-ring kit
-Heater Tube O-ring
-Motorcraft Crank Sensor
-Hpop Gasket Kit
-Updated Turbo Oil Drain
-Standpipe & Dummy Plug Kit
-Blue Spring Kit
-6.4 Pushrods
-6.4 Lifters
-Cam position sensor
-Racor Oil and Fuel Filters
-5w-40 Synthetic Oil
-CAT Extended Life Coolant
NO PUKESTERS
95,346
This?
"Leak Detector Kit / Engine Block Test Tools Inc. BK 7001006 | Car Parts & Truck Parts | NAPA Auto Parts" https://www.napaonline.com/en/p/BK_7001006
Yes. Go beat it up, good and hot, release pressure, then have some one take it up and down to about 3k rpms slowly while you squeeze the bulb and SLOWLY let it suck in from the degas bottle. Don't let it ingest coolant
Reactions: GTPpower
GTPpower
6,344
9,742
Nebraska
Ran the test a couple times. No sign at all of a leak.
But I still have a small coolant leak that shows up when I let this thing sit for a day without starting it. Usually I don't start it Sunday, and there will be a small coolant puddle under the rear, passenger side of the engine Monday morning.
NO PUKESTERS
95,346
But I still have a small coolant leak that shows up when I let this thing sit for a day without starting it. Usually I don't start it Sunday, and there will be a small coolant puddle under the rear, passenger side of the engine Monday morning. I'm going to pull the charge pipe and inspect the egr delete on Saturday.
And this test was done after a high heat run and someone taking rpms up and down gradually?
GTPpower
6,344
9,742
Nebraska
Yes, I had my dad bringing rpms between 2k and 3k while testing. I'm thinking the reason the Degas bottle was leaking was just a weird circumstance from the super cold weather we had. I'll get this thing up to operating temperature, release the pressure, then beat the ever living shit out of it, and I can't even get the gauge up to 10 psi.
I'll have to take another look to see if I can find where the leak is coming from.
Reactions: DEEZUZ
Rdrnnr
wannabe racecar builder
Nov 15, 2020
1,361
2,386
Why does everything with Ford diesels have to revolve around the cooling systems. You ever tried this stuff man? In the idis adding scas is pretty necessary to keep bubbles off cylinder walls creating hot spots idk if it'd help here at all or if its somewhere in the 20 pages of all this already but it's instantly my first thought after reading into a couple pages anyway. 20210515_133413.jpg
