-Headstuds
-4" Turboback Exhaust
-Edge EGT Probe
-Mishimoto Coolant Filter
-Valvecover Gaskets
-Rear Main Seal
-Updated Oil Cooler
-Rear Cover Gasket
-Updated Turbo Feed Line
-Rocker Box Gasket
-Injector O-ring kit
-Heater Tube O-ring
-Motorcraft Crank Sensor
-Hpop Gasket Kit
-Updated Turbo Oil Drain
-Standpipe & Dummy Plug Kit
-Blue Spring Kit
-6.4 Pushrods
-6.4 Lifters
-Cam position sensor
-Racor Oil and Fuel Filters
-5w-40 Synthetic Oil
-CAT Extended Life Coolant
GTPpower
6,347
9,750
Nebraska
I will keep an eye on it. I've been trying to remember to power on the monitor before starting it, but that doesn't always happen.
I'm going to get the ipr external oil cooler. I'm also going to switch to their coolant filter. I was going to backflush it, but decided not to. I just don't want to have to go through this every year. I'd just rather pay a bunch once to fix it and never have to worry again.
GTPpower
6,347
9,750
Nebraska
I haven't cut any of them open, but I dump them out in a bowl. There is always black particles that comes out. Maybe casting sand or some sort of rust. Ive been changing the coolant filter about every oil change since I've had it, and I don't think the amount of junk that pours out of the filter has decreased any measurable amount. I've put about 60k miles on it, so that's maybe 10 filter changes.
NO PUKESTERS
95,657
Either way if I had your current issues, I'd leave all the parts on engine, pull both block drains, vacuum fill with distilled water and VC9 cleaner. Run the engine for 2 hours at 1700 rpm with a cold front(cardboard). Drain everything. Flush heater core, blow it out with air. Refill distilled again and flush until it all drains clean, pull tstat if you want to for increase flow.
Then change the hoses(if they have caked innerds) radiator, oil cooler.
