GTP- New PCM, remote start INOP
NO PUKESTERS
95,665
Installed a ZZP PCM and now remote start will not work. The car will turn ignition on, but it will not crank and in the DIC it will display a message stating that the starting system is disabled due to theft. I did program the PCM via tech2... not sure if there is a key hidden somewhere in my dash or not that needs to be reprogrammed..
NO PUKESTERS
95,665
gm tech 2 scanner..
did you use one to program the replacement PCM for your car?
there is a securities menu that you can go into and see what is making the security system angry.
Yes I programmed with tech 2 since even the key wouldn't start it after replacement.
does it remote start with the key in it or near it? if it has a coffin and wires near the cylinder there is most likely a key buried in it.
I will try with key near the ignition
