grinding/rattling under hood
2000GTPK
i have a 2000 GTP when i have the AC, OFF theres a loud grinding noise MOST OF THE TIME. it sounds like its coming from under the snout on the SC. when i turn the AC ON the sound ALWAYS goes away. i cant figure out what it would be. someone said it might be the AC cluthc bearing.
if i buy an AC delete pulley system do you think id be ok or do you think its a different pulley, bearing or problem
Toasty
Bolingbrook, IL
[/b]
since nobody replied to you already, your a/c clutch bearing is shot... if it hasnt already, it will eventually sieze on you and burn/break your serpentine belt.
hit up ed morad (gtped at msn dot com) for a good used one
