Grey RTV...Cure Time?
TommyGloves
CHICAGO
If you use grey RTV as your gasket between (say a SC, IC core and intake) what is the amount of time that it needs to cure before you should start the engine or drive the car?
TIA
grey permatex or grey mopar rtv?
you should be good to go after just an hour but larger (like 3/8ths+ thick) blobs can take 4 or more hours
you ever stop and get a set of cheapo sockets?
TommyGloves
CHICAGO
[/b]
Yep...I was going to call you today anyway to make arrangements for the work I need to get done. :) I'll give you a call later today.
