Grand Prix Brake Lines
Fast99Snake
track rat
Jun 26, 2005
1,590
So the hard lines finally gave out on my brothers 1998 grand prix today, had been meaning to replace them soon anyways.
Based on the information I have found on the net I have determined lines are 3/16ths.
My question really is if I will need a DOUBLE flaring tool or a BUBBLE flaring tool? I'm going to replace the rear lines all the way up to the abs module and I'm just going to buy the big roll of line and flare them myself re-using the old fittings off the oem lines. So are the OEM lines double or bubble flares?
Thanks much
RICH17
Dr. Pussy Slayer, MD
26,707
1,992
The 007
Adam Rich
They are bubble flare. You can do what James had said but you can also but adapters from Napa that are metric bubble on one end and 1/4in double flare on the other. It mkaes it look a bit messy IMO but it does the job just fine. Also if you're making any connections be just to find steel fittings and not brass one. They cost a little bit more but a worth it
Fast99Snake
track rat
Jun 26, 2005
1,590
Finished this up today, ended up just doing all new hard lines to all four wheels since they all were severly corroded, wasn't that bad of a job just very time consuming.
Although now I'm looking at all these nasty fuel lines that don't look like they're very far behind especially back by that drivers rear wheel. Anyone got any tips on those? I know they're 3/8 and 5/16 lines.
DanJ
33,568
16,929
Small world. I went to take my fuel filter off today and the flare nut is completely fucked. Seized to the line, threads are in bad shape, etc. think I'm going to cut that section out tomorrow and fix it with new line and a flare union.
RICH17
26,707
1,992
The 007
Adam Rich
Yea the fuel lines are basically the same as the brakes. But the fittingd are different. You can get a small peice of line with the fitting already on it from most parts stores. You cannot make the fitting because it uses an oring to seal. Just buy the adapter and flare to that
