- Joined
- May 23, 2007
- Location
- Avondale, AZ
It's not like you have any social events to engage in this weekend... get to it.
Oh look, it's so small it fits in your pocket. Awwwww.
1. Physics Simulation Model
- The behavioral models for the suspensions and the steering have been adjusted:
・The calculation of suspension geometry has been improved, resulting in more natural cornering physics and acceleration/deceleration stability levels.
・The calculation of steering geometry has been improved, resulting in more accurate simulation of steering forces.
・Damper attenuation behavior was adjusted, resulting in more natural physics on road bumps and curbs.
- The tire physics simulation model has been enhanced by:
・Turning stability on low speed corners and curbing has been improved.
・Surface resistance (rolling resistance) has been optimized.
・Heat and wear behavior were adjusted on racing tires.
・Grip reduction on the racing line in wet conditions, and hydroplaning physics were adjusted.
- Default settings have been improved.
・Initial suspension and aerodynamics settings have been changed on all race cars and certain road cars.
- Performance Points (PP) for all featured cars have been updated.
- The wireless controller steering algorithm was updated.
・The steering algorithm when using the analogue sticks and the directional pad were enhanced, resulting in better handling.
- Controller behavior for steering wheels have been updated.
・The force feedback algorithm has been adjusted, allowing devices to use their full torque range.
・The steering geometry calculation have improved, resulting in better force feedback feeling.
- The effects of the following driving assists have been improved.
・The Traction Control (TCS) assist intervention has been optimized;
・Corner braking control for ABS (anti-lock brakes) has been optimized.
2. Controllers
- We addressed an issue in which force feedback vibration on the Logitech® G923 was too sensitive.
- The strength of the vibration effect on the Logitech® PRO Racing Wheel has been adjusted.
- The performance stability for all Fanatec® steering controllers has improved.
- The LEDs of the four sticks on the Fanatec® GT DD Extreme will now light up in the color of the corresponding MFD.
- We also adjusted the Tuning Menu Auto Setup parameters for the Fanatec® GT DD Pro/Extreme, and Podium.
Selecting "Auto Setup" (AS or A SET) from the Tuning Menu on the wheel will load the optimal parameters for playing Gran Turismo. A firmware update may be required in order to enable the Auto Setup function on your device. In Podium mode, Auto Setup is intended for use in Low Torque mode. The use of High Torque mode will require manual adjustments.
3. World Circuits
- Time settings have been adjusted for all Circuit Experience events, and all demonstration replays have been updated. Also, all rankings boards have been reset.
4. License Center
- Time settings have been adjusted for all License events, and all demonstration replays have been updated. Also, all rankings boards have been reset.
5. Missions
- All rankings boards have been reset.
- The difficulty level has been adjusted for the following event:
・Tsukuba Circuit One Hour
Yeah, and another fucking van.
Makes me miss PGRAnd another fucking GTR.
Those chicago backdrops look great tho.
