Got a buddy with a '72 396 small block
Slow Buick
eat ass drive fast
In an 87 camaro. Only thing he can't figure out is how to adjust valve lash. How does one go about that? I'm posting up and he will read it later.
Slow Buick
eat ass drive fast
I will ask. I think he said solid but I am not sure.
Mr_Roboto
Joliet
Over all it's pretty simple usually. You position the engine so that half the lifters are on the base circle, if they're hydraulic I take em till the valve is tight+ 1/2 turn extra otherwise you're going to need feeler gauges and the lash specs for what you're running. After you lash that set (find a book, it will tell you which ones to lash with the engine in what position) then you rotate it 360 degrees and do the other half of them. Not a huge deal, pain in the ass if you're like me and have done it a total of 4 times.
Slow Buick
eat ass drive fast
So if some one was doing it for the first time what advice you got for that
1quick
coal city
Small block?
I think a 383 stroker bored out to 100k would get you really close to 396, the silver s10 on here is 388 at 60 over, I'm pretty shire you can just use a slightly shorter rod in a 400 to make a 396 also
Mr_Roboto
Joliet
4 inch stroke crank 4.030 bore. Not common and def not oem. Prob a bbc
Aron
Scared pussy
Rod length has no impact on displacement. It's all bore and stroke.
p.s. a 396 is a big block
Slow Buick
eat ass drive fast
Ok , its actually a hydraulic lifter.
Trying to get him to sign up
Slow Buick
eat ass drive fast
He is thinking about having a shop do it. Jeff, what would you charge? Heads are off the block.
Mr_Roboto
Joliet
Uhhh, you're not lashing anything with the heads off the block mang.
Slow Buick
eat ass drive fast
Meant to say on the block "and everything" lol dunno why swype did that.
