So I’m looking for some ideas/ advice for my trusty steed. My ‘05 Yukon has been getting rapidly worse with oil consumption as well as smoke on startup. I’m having to add around 4 quarts during a 5,000 mile oil change interval. The smoke on startup has gotten easily 3-4 times worse than its ever been within the past week. It is usually the worst after driving for a while, letting the truck sit for 2-3 hours and then starting back up, but isn’t great on a cold start. Nothing noticeable on hot restart after 30-40 min or less though.
I work the shit out of this thing. It tows a small trailer almost daily and plows snow all winter. It runs buttery smooth, has no engine lights (active, soft codes, etc), is not down on power whatsoever, still pulls high 17’s to the gallon on the highway and makes 42psi hot oil pressure at idle and north of 60 at 2,000 RPM’s.
With that said... it has 298,000 miles and 10,100 engine hours. Am I right to suspect it’s not engine hard parts related getting so much worse so quickly? From what I’ve heard a faulty PCV valve could cause smoke on startup? These are integrated into the drivers side valve cover but a set of VC gaskets would do it right as well.
Im perfectly OK with adding 2qt’s of oil every 2,000-2,500 miles since it just gets the cheap shit anyways, but if there’s something to be done I’m all ears. I’d hate for it to start causing other issues like clogging cats and shit (if that’s even a thing)... I’m trying to nurse this thing along as long as possible within reason as a daily and then probably as a dedicated plow truck.
