GI demod
easytoremember
Active member
Brew City
Guaging Interrest, Demodding this november if I can get most of this stuff gone.
heads $1500
The same as the INTENSE Stage 3 heads. Full port work, almost brand new manley valves. 1.9 intake 1.57 exhaust heads recently cleaned and decked, and painted pontiac blue
race trans $3000
You name it, this tranny has it, even low miles, about 10,000 to be exact. Here’s the list. Also painted pontiac blue Tranny done by Tim King at Intense in January of this year.
Gen 3 Limited Slip Diff (499.99 new)
INTENSE Street / Strip shift kit (129.99 new)
ATI torque converter 3000 stall 399.99 new
Speedo recalibration controller 99.99 new
3.69 gear conversion kit 489.99
VSS Reluctor wheels 59.99
INTENSE Hardened Input Shaft 449.99
Drilled flexplate 40 new
ARP flexplate bolts 20 new
New Valve body 80 new
New Input, 2nd 3rd, and and overdrive clutch kits 27 new, 35 new, 35 new, 28 new
New wiring harness 60 new
I may be missing parts but that’s all I remember
prj rails Silver rails with fuel pressure regulator $250
Custom PCM . I’ve put hundreds of hours into this tune. $100
Cometic MLS .051 head gaskets new gaskets were used doing this rebuild this month, there will be less than 1000 miles on these gaskets when I sell $90
btk intercooler used on Jeff Smith’s car to put him into the 12s….. years ago with stock heads, blower and cam! Complete with the really cool grooved intercooler core, probably one of the nicest looking cores, this core is 1 of 1. Jeff only machined the grooves for his own core. Also included is the custom ice box, and brackets he made for the trunk so you can dump in lots of ice to get super cold water to the core. Flowjet pump, wiring, lines, and heat exchanger as well all included. $900
INTENSE stage1x cam used for about 30,000 miles $75
double roller New chain used for this rebuild, will have less than 1000 miles on it when I sell. $100
gen V M90 supercharger Painted gloss black with 3 coats and 2 coats of clear coat. Lines have been painted pontiac blue as well. Has INTENSE modular hub on it. Many pulleys available. $750
Northstar Throttle Body Brian Teel’s kit! looks wonderfull. Painted gloss black, paint can be touched up or stripped off. $200
Lucas 42.5 injectors Bought from Zoomer a couple years ago. $175
Ported Lower Intake Manifold Modified for Gen V Blower. Painted Pontiac blue as well. Also modified for the BTTK Intercooler. $100
TOG headers wrapped with Charcoal Header wrap $700
Modular pulleysn for the intense, zzp, or w body store system!!!
3.4 40
3.2 40
3.1 40
3 40
2.9 45
2.8 45
Hoosier Quick Time Pro wheels with 15” American Racing rims. Lighter than stock rims 350
prj wires number 1 boot has been replaced and does not match the set. Also included will be a set of fiberglass boot protectors 100
Intense OR push rods $70
Walbro pump $120
Custom fiberglass 3 Guage A pillar for 94-96 pontiac grand prix coupe $200
Autometer sport comp guages and wiring harness
Electric oil guage with sending unit $40
volts $30
boost $30
pre 97 parts
custom fiberglass door pannels for 6.5 component speakers $175
B4U trim White, front bumper is scrached on bottom, across front, cracked arrowhead, cracked on driver side by wheel well underneeth. $150
Heads Up with dash pad and switch $150
Charcoal leather interrior $150
full exhuast for 94-96 Grand Prix with L67 3” from downpipe to catback. 2.5 Y to dual 2.5 inlet outlet borla mufflers. 300
ARP Re-useable rocker bolts $15
Chrome Oil fill Breather $25 (2 available)
Ill add more as I can think of it. PM me if interrested in the whole car or the whole drivetrain. Thanks for looking
Z
I
imported_1fastGTP
interested in the prj rails milage and what gen?
REDHOTT04GTP
Romeoville
heads $1500
race trans $3000
3.4 40
3.2 40
3.1 40
3 40
2.9 45
2.8 45
Walbro pump $120
volts $30
boost $30
pre 97 parts
Z
[snapback]139889[/snapback]​
Will thoes heads work with a 04GTP?
I
imported_silverbullet
i'm interest in the nothstar TB. do i need to buy anything for it?
easytoremember
Active member
Brew City
I do not know if the heads will work on an 04, ed morad might know.
fuel rails are spoken for already
the N* TB kit is complete nothing else needed Bumpin I owe ya one so sorry I'll have to bump him to the top. Steve, hit me up on AOL Im if you're around I need some help deciding which car to sell :)
SaturdayGS, any information you need? or are you interresed like "when you demod call me and ill get you payment" or is it more like "wow that's interresting"
smkn same question? how interrested, and any info you need?
xtant12, sorry someone is inline for the injectors
keep the bids comming!
SaturdaysGS
Chicago (Southside)
[snapback]139963[/snapback]​
Sorry about that, if its in "good shape" (I dont see why it wouldnt be) when it comes out of the car, then consider it sold.
smknL67
Bensenville
I'll buy those gauges whenever your ready....I'm not 100% sure how to install them so I might need a bit of help with that but I got $$ on hand.
I
imported_1fastGTP
yea how come everytime i have first dibs on something/money on hand its always spoken for!? blah!
smknL67
Bensenville
So what happened with the gauges? U never got back to me. I still got the $$, so when can I pick them up?
easytoremember
Active member
Brew City
the demod is after IDD nov 3rd, sorry i thought i replied, you got dibs on the guages. i just noticed working on the car today that the trim rings on the boost and the oil are not perfectly round anymore (dropped them when installing) ill get pics when it all comes off
