Bought a 2005 Centurion Avalanche in July. Only had 350 hrs on it. I bought it without testing it because it was still winterized at the time. Owner had some service stuff and the guy that winterized it, vouched that it was a great running boat w/o issues. Well... Took it out on the water and the first day, the impeller went out. Had to get it fixed. After it was replaced, took it out again and a hose got loose and dumped water all over the engine. Fixed the hose but it was having starting issues. Took it to a different shop. They replaced the starter, did some minor maintence stuff (spark plugs etc..) Said it ran great. I took it out but didn't really get to test it because the water was too choppy and I didn't feel comfortable with the size of the waves. Took it out this weekend. Ran good for a bit. It did die a couple times but started up without issue. On the 3rd time, I had someone on a wakeboard behind and as I started to accelerate quickly it died, and wouldn't start. Not sure if I accelerated too quickly or what. Trying to diagnose this starting issue. It has a carburetor engine & one thought is that I flooded the engine with fuel but even after letting the boat sit for a while, it still wouldn't start. I'm going to look into cleaning the carbs this weekend.
The starting issue has been a problem since day 1. First time I thought it was a safety feature or something when the engine overheated. Second time, I thought it was because the engine flooded with water. That's when the shop replaced the starter. This last time, no idea. I've had a max of maybe an hour on this thing without issues. The other issue is that it runs perfectly fine on land, but the only real way to test it is in the water. I'd love to get one really good boat day before end of October & I need to put it away.
