gas pedal and hood latch
gtp02
gtp
northlake
popped my hood today and now it wont shut all the way, any input? and the gas pedal is sticking alittle causing the car to keep accelerating even when foot is off the pedal. any help or input would be great. thanks
syP
Not Banned
Downers Grove, Illinois
for the hood.. the line probably froze..
take out a hairdryer with with extension cord and heat up the hood latch for a little bit.. bet it will close
02BlueGT
No Fucks Have Been Given
Now apearing in Hanover Park
The pedal, check the throttle for build up, this will cause the plate(and the pedal) to stay open. If that is all clean, check the throttle plate, and see if it sticks anywhere.... of thats all good, check the pedal assembly, and see where it is catching, and what repairs are needed....
Most of the time though, the stick pedal is from gunk build-up in the throttle Body, It's rare(not unheard of, just uncommon) for the pedal assembly to have issues
Fish
From the mean streets....
Chiraq
The latch on my car freezes and wont close all the way, unless I pull in the garage and let it heat up.
Damn GM latches. They seem to be always broke. Especially when you wanna race. :s00ls:
