Garage heater advice
Gamble
1,935
738
Got a little 220v heater but doesn’t do much for my garage since it’s 3 car.
I had a gas line ran and found this at homedepot
ideally want one that only burns outside air and vents back outside but I don’t have $2k to drop.
Anyone use this or have any experience with it or should I buy a mr heater hotdawg from menards for $369, then whatever it costs for the exhaust vent and other shit. Really not crazy about drilling holes in my new siding nor can I afford to pay someone
https://www.homedepot.com/p/Reddy-H...3;301695639;100125308;203633490;100179498;-_-{{productId}}-_-N#product-reviews
1quick
26,610
24,225
coal city
ive used one just like that for 6-7 years and it works very well, I have it turned down to the first position of heat right now my new garage is very insulated it keeps it around 55 at that setting
Knowklew
1,900
103
MrDragster1970
4,919
1,774
RT 66 area
I have that 30,000 in my little shack/cabin.
I don't notice the smell at all, and I have never smoked and have a very sensitive nose.
Others have said they smell it immediately, others don't??
I have 2 CO2 detectors, including 1 that is 3' away and they have never gone off.
It will definitely keep it warm, I'm at 700-800' I believe, and it's on setting 2 of 5.
I would guess anything with finished walls & ceilings would stay warm enough, even without a ton of insulation.
Much cheaper than electric.
daturbosix
HNIC @ GoodFellas Garage
16,459
15,456
Jeff
Kind of nervous to blast a 3 or 4” hole in the siding
You guys have pics of your setup and the vent that goes outside?
Does that thing come with everything I need or will I need other stuff to?
i can take some pictures of my reznor. it would be the same deal as the Mr heater unit.
but really simple. just bore a 6" hole through the wall and siding, then place and caulk your thimble in place
here: https://www.homedepot.com/p/Selkirk-3-in-Type-B-Adjustable-Wall-Thimble-187703HD/300255799
then get some duct and pipe it through it, finish it with a weather cap vent thingy.
MrDragster1970
4,919
1,774
RT 66 area
Vented is better, I went with unvented because it has electric heat, and the 1st 2 days I used the place it was over $5 a day.
So I just grabbed what they had before I went broke every time I used the place.
Plus it's temporary until this big Chicago contract is over than I'm moving every thing to Indiana, house, shop & shack!!!
I put an option on the spread 2 doors down from DEEZUZ!!!!
Chris91LX
Addict
621
1,245
Crystal Lake
Here's mine. The chimney was not as bad as I had feared to install. Vented heaters work so much better.
Gamble
1,935
738
Well I bought the first one since it was $189 at Menards only to find out I don’t have anywhere to mount it. Needs 8” free on each side and 36” from the ceiling. So will get the other one. A guy that did work for me before said he would install it for $150 plus parts. I can work with that I think
