Game Over Cancer....
tinfoilhat
Riding the Hubble
:jg:
oh and LOL at 2007...
(NaturalNews) A safe and effective cure for cancer has been discovered with a drug that was once used for unusual metabolic problems. Yet, the cancer industry shows no interest with following up on dichloroacetate (DCA) research from University of Alberta in Edmonton, Canada, reported in 2007. That's because DCA is no longer patented. (1)
That research also confirmed cancer as a metabolic malfunction, not a weird mutation of cells often explained away as a genetic issue. But the medical mafia doesn't want you to hear about it. But it confirms what most alternative cancer therapists already know.
Since Nixon declared the "war on cancer" in the 1970s, the cancer industry has succeeded with raising money for researching very expensive chemo substances at $50,000 to $100,000 per round or more for toxic therapies that rarely work. (2)
Chemo drugs usually lead to demanding more business with drugs to ease terrible side effects (http://www.naturalnews.com/034761_cancer_drugs_toxicity_Voraxaze.html). Meanwhile, more are getting cancer and more are dying from it, mostly because of the toxic treatments.
Explaining DCA research results
Evangelos Michelakis and the Alberta University research team tested DCA on human cancer cells outside the body and in cancerous mice with profound success. DCA was once used for unusual metabolic disorders. The worst side effects, which rarely occur, include some numbness and an affected gait.
The mice were fed DCA in water, and in weeks they had remarkable tumor shrinkage. This indicates DCA can be taken orally. DCA works by restoring the cells' mitochondria. Michelakis and his team had discovered that the mitochondria in cancer cells are not permanently damaged and irreparable. This is what mainstream medicine thinks.
With mitochondria malfunctioning, cancer cells use glucose fermentation for survival energy. This fermentation occurs when glycolysis (glucose conversion) occurs in an anaerobic cellular environment, which can be created by benign tumor masses, toxins, and low pH levels.
DCA restores mitochondria in cells to make them function properly. Another function of normal mitochondria is signaling apoptosis, or cellular self destruction. Normal cells die and become replaced constantly. But with cancer cells, the apoptosis signal is nullified, making cancer cells "immortal." (3)
The Alberta University researchers also realized that glycolysis fermentation in cancer cells produces lactic acid. The lactic acid breaks down the collagen holding those cells together in a tumor. This allows cancer cells to easily break away from a tumor shrinking with mainstream therapies.
The researchers reasoned this is why cancer metastasizes or spreads to different parts of the body or reappears after remission from chemo.
Tragic hypocrisy
Alternative cancer therapies have little or no problem with metastatic cancer or even cancer reoccurring after remission. Most alternative cancers simply cure cancers completely.
DCA offers the cancer industry an opportunity to come up with a pharmaceutical cure that is much cheaper and safer than their current standard of care. Yet the cancer industry is ignoring this opportunity. Instead, DCA is a homeless orphan begging for research funds to avoid legal issues with off label use on cancer. (4)
Alternative cancer practitioners have always simply tried out and when they succeeded shared them with others who cared more about healing than money and power.
The medical mafia has created a matrix that demands big bucks to make big bucks for sick care instead of curing. Everyone in on the scam makes out financially. The cancer industry accuses alternative cancer therapists of quackery and taking advantage of the desperately ill for financial gain. Accusing others of your motives and crimes is called projection.
The medical/pharmaceutical complex is crony capitalism that doesn't want a cure for cancer from anywhere.
Learn more: http://www.naturalnews.com/034823_cancer_industry_patent_protection_drugs.html#ixzz1l4xDY67x
Harbor Master
i sort of want to believe this. but your conspiracy stuff just doesn't ever sit well with me.
tinfoilhat
Riding the Hubble
:rofl: theres MANY CURES FOR CANCER....WELCOME TO REALITY
links on that site include this one
http://www.dca.med.ualberta.ca/Home/Updates/2007-03-15_Update.cfm
The University of Alberta Discovery
March 15, 2007
DCA is an odourless, colourless, inexpensive, relatively non-toxic, small molecule. And researchers at the University of Alberta believe it may soon be used as an effective treatment for many forms of cancer.
Dr. Evangelos Michelakis, a professor at the U of A Department of Medicine, has shown that dichloroacetate (DCA) causes regression in several cancers, including lung, breast, and brain tumors.
Michelakis and his colleagues, including post-doctoral fellow Dr. Sebastien Bonnet, have published the results of their research in the journal Cancer Cell.
Scientists and doctors have used DCA for decades to treat children with inborn errors of metabolism due to mitochondrial diseases. Mitochondria, the energy producing units in cells, have been connected with cancer since the 1930s, when researchers first noticed that these organelles dysfunction when cancer is present.
Until recently, researchers believed that cancer-affected mitochondria are permanently damaged and that this damage is the result, not the cause, of the cancer. But Michelakis, a cardiologist, questioned this belief and began testing DCA, which activates a critical mitochondrial enzyme, as a way to "revive" cancer-affected mitochondria.
The results astounded him.
Michelakis and his colleagues found that DCA normalized the mitochondrial function in many cancers, showing that their function was actively suppressed by the cancer but was not permanently damaged by it.
More importantly, they found that the normalization of mitochondrial function resulted in a significant decrease in tumor growth both in test tubes and in animal models. Also, they noted that DCA, unlike most currently used chemotherapies, did not have any effects on normal, non-cancerous tissues.
SMRTSS1
Cure for cancer will never be allowed, there's too much money in treatment, too many people getting rich off of it and it's a form of population control.
Turk
Lt. Ron "Slider" Kerner
SilentSMRTSS1???
Turk
That's fine, obviously there's something wrong with it since it's not being used. Have you red about HIV being able to only infect cancer cells too? They are working on that also.
tinfoilhat
Riding the Hubble
or because it would literally end the cancer industry and the thousands of jobs and trillions of funding
Turk
There's a cancer industry?
SleeperLS
Desert Racer
Sandia Mountain
There is no cure for cancer. few cases go into remission and stay that way forever. There are many different types of cancer which make it a very Complex disease. Oh and LOL at cancer being a metabolic disorder. There is a guy that feels giving yourself coffee enemas every day cures cancer.
Yes chemo is really nasty shit. But it is still one of the few drugs we know of to be effective on certain cancers.
Turk
No, I just regurgitate bull shit from tinfoil hat websites. Find me the fucking clinical study that doesn't exist.
The University of Alberta's DCA Research Team is set to launch clinical trials on humans in the spring of 2007 pending government approval. Knowing that thousands of cancer patients die weekly while waiting for a cure, Dr. Michelakis and his team are working at accelerated speed, condensing research that usually takes years into months. Fundraisers at the University of Alberta are determined to raise the money to allow this next phase of research to begin. Once Health Canada grants formal approval, the University of Alberta's Research Team will begin testing DCA on patients living with cancer. Results with regards to the safety and efficacy of treatment should be known late this year.
Turk
BTW, it's still IN TRIAL, which takes years if not decades to approve. So take your conspiracy theorist bull shit elsewhere, if it works, it will make it to market, like any other drug. In Alberta's phase II trial, they took 5 people that had cancer, treated them with this stuff and one died in 3 months. Sounds like quite the wonder drug to me.
Turk
It will be cured one day. The idea of having a virus attack cancer cells only intrigues me, much more than this DCA.
SleeperLS
Desert Racer
Sandia Mountain
does anyone actually read on this forum or just spout off opinions?
So somehow these crackpot theories you read on the internet count as more than a opinion? Using current medical knowledge that is in practice is somehow not valid? Just because an idea looks promising does not mean it is going to work. That is where this thing called research comes in....there is a lot of shit that doesn't pass the test because the theory did not end up being reality. Have you ever studied or treated any type of cancer process? do you have any idea what goes into having a serious diagnosis of cancer?
tinfoilhat
Riding the Hubble
http://www.dca.med.ualberta.ca/Home/Updates/2010-05-12_Update.cfm
The U of A team set out to show that the way that DCA works in actual patients is the same with the way it works in the lab. In addition, researchers wanted to show whether DCA is safe and possibly effective in very sick patients with brain cancer.
By extracting glioblastomas from 49 patients over a period of 2 years and studying them within minutes of removal in the operating room, the team showed that tumors respond to DCA by changing their metabolism. Then, the team treated 5 patients with advanced glioblastoma and secured tumor tissues before and after the DCA therapy. By comparing the two, the team showed that DCA works in these tumors exactly as was predicted by test tube experiments. This is very important because often the results in non-human models tested in the lab do not agree with the results in patients. In addition, the team showed that DCA has anti-cancer effects by altering the metabolism of glioblastoma cancer stem cells, the cells thought responsible for the recurrences of cancer.
In the 5 patients tested, the drug took 3 months to reach blood levels high enough to alter the tumor's metabolism. At those levels, there were no significant adverse effects. However, at some of the higher doses tested, DCA caused nerve malfunction, i.e. numbing of toes and fingers. Importantly, in some patients there was also evidence for clinical benefit, with the tumors either regressing in size or not growing further during the 18 month study.
SleeperLS
Desert Racer
Sandia Mountain
Yeah what Turk just said in his last couple posts. The virus idea is exciting. I would be pretty concerned about any virus evolving and losing its effectiveness/programmed function. I don't think we would have any rediculous idea like zombies, but people would prolly just get really sick.
Turk
BTW, nothing gets approved with a sample size of 5 patients! :pICARD:
