2007 Infiniti G35 Coupe
Red / black leather heated power seats, power sunroof
stock 19 inch wheels, its lowered on springs but im not exactly sure wich ones
new brembo front brakes, calipers, rotors, pads.
stock rear brakes
COMPLETE LOJ Conversions Corp - Ultimate Swap Kit
Engine -
2008 Savanna Van 4.8, 58x Gen4
Elgin 1840p Sloppy stage 2 camshaft, pac1218 valvesprings, elgin pushrods
heat range 8 iridium plugs, taylor custom wires
Kooks custom stainless longtube headers from LOJ
ebay 2.5 inchcatback with resonators, mufflers, etc, "Loud" but does not drone at all at cruise
Complete LOJ 8 Rib Accessory drive using stock nissan accessories wired plumbed correctly with their kit
8 Rib 2.44 back cut pulley on stock unported LSA blower, 10% over driven SFI crank pulley
ZL1 Lid welded, with AN fitting block on blower lid, stock LSA fuel rails, SEP 1000 injectors.
LOJ Oil pan, LOJ oil filter relocation kit, Lines, etc etc
Lowdoller motorsports fuel pressure regulator, oil pressure sensor, post filter pressure sensor,
Snake Eater Performance 92mm Matte Black DBW throttle body
Custom Cold air intake down into front kidney grill with KN filter built by AREA1320
LOJ Custom C&R aluminum radiator and fans
Large front mounted heat exchanger with fill fitting, Bosch water pump
Fuel System -
Holley two stage Brushless in tank pump and controller managed by holley
converted stock hat to return system using PQY regulator
Radium engineering Saddle tank syphon kit installed on return
GM Continental Flex fuel sensor installed and working with holley ecu
all PTFE high quality nylon braided lines from monkey fab
-8 feed -6 return
Nitrous -
Nitrous outlet 400hp Nitrous plate.
Nitrous outlet 10lb bottle, 4an Feed line
Lowdoller motorsports Nitrous pressure sensor
Nitrous outlet bottle warmer
the entire nitrous system including bottle warmer is managed by the holley system,
its Dry and adding fuel with the injectors. its all enabled with one easy switch near shifter
Drivetrain -
Complete LOJ Kit for the driveline
LOJ transmission adaptor for the LS to stock trans CD009 nissan trans
Clutch Masters custom flywheel for LOJ swap,
Clutch Masters FX1000 Twin Disk 10 inch clutch rated for 1000+hp
LOJ Custom driveshaft speed sensor wired to holley VSS input
LOJ custom aluminum 1pc drivshaft
Stock IRS rear end with solid diff / cradle bushings
ECU Dash displays -
Holley Termintator Xmax ECU
Holley 7 inch touchscreen dash
Holley 3.5 inch touchscreen dash
Holley 58x engine harness
Car makes 17lbs of boost and 600+rwhp on blower only
I currently have 100shot jetting in nitrous kit
I detuned to 580whp (absolutely bonkers to drive) and sprayed to 684whp easily for fun
car has injector and fuel pump left yet to make more in all fronts.
Car heat, and AC works with LOJ control box.
youtube playlist of entire build
stock rear brakes
Engine -
Fuel System -
-8 feed -6 return
Nitrous -
Drivetrain -
ECU Dash displays -
