FS(USED): RCI 2030 3 gal Aluminum Resevoir
Flatliner
I'm kind of a big deal...
Just bought this used from a board member, but not going to fit where I wanted it, so I have to let it go. $120/ obo with fittings.
8x8x15
RCI 2030A Aluminum fuel cell.
All of RCI's lightweight aluminum fuel cells are TIG welded from 5051 aircraft quality aluminum alloy. They feature a 12-bolt, flush mount aircraft style filler cap and come in a natural aluminum finish, or powder coated in red, blue, or black. There are two #8 AN pick-ups and one #8 AN return fitting and one rollover vent. The 10, 15, and 20 gallon models also include a 0-90 ohm sending unit and all except the Pro-Street models include safety foam.
8" x 8" x 15", 3 gallon capacity.
Brand RCI
Manufacturer's Part Number 2030A
Part Type Fuel Cells
Product Line RCI Aluminum Fuel Cells
Summit Racing Part Number RCI-2030A
Capacity 3 gallons
Fuel Cell Color Natural
Fuel Cell Material Aluminum
Foam Yes
Sending Unit Included No
Length (in) 8.000 in.
Width (in) 8.000 in.
Height (in) 15.000 in.
Outlet Fitting Quantity Two
Outlet Fitting Size -8 AN
Return Fitting Size -8 AN
Tip Over Valve Size -8 AN
Bigturbonotch
WAIT AND SEE
hmm tempting, might use it for me a/w intercooler, ill let you know.
Flatliner
Flatliner
No problem, just let me know and make an offer :D
Flatliner
Flatliner
Bump, make offer, must go!
Flatliner
Flatliner
Bump, make offer
IZZy
Powered by ES
would there be any chance of mounting this in the engine bay?
maybe with the battery relocated, it looks small in that picture but if it holds 5gal. then it cant be that small.
Flatliner
Flatliner
I'll post a better pic tonight, but it's bigger than what it looks.
Flatliner
Flatliner
Bump added more pics too!
Slow99x
ZOMBIE kill of the week
Yes it is. I saw it first hand today. It's close to the size of a larger size nitrous bottle but not quite as long. It would be good for a trunk mount. The welds look good BTW.
Lightning Bob
Victor,
Does your tank actually measure 12" in two directions? If so, the height must be even longer based on the pictures you posted. Yours looks more like the RCI-2030A which is 8"x8"x15" and holds 3 gallons. I don't mean to detract from your thread, only to help you clarify for those interested who could then fit it in their vehicle.
Either way, Good Luck with the sale.
LB
Flatliner
Flatliner
:eek: I'll have to double check it ;)
Flatliner
Flatliner
Bob is right... I had the wrong model, it's actually the 2030, 3 gallons. Looks like new they are about 139ish, so with fittings (turns out I can't use them) 120/obo.
Sorry for the confusion.
deviantlx
i got four crispy 20's sitting burning a hole if you wanna unload it. let me know.
Flatliner
Flatliner
Make it $90 and yours... come pick up in Streamwood/ Rosemont...
otherwise I be at Byron tomorrow, let me know and I bring with, make offer!!
deviantlx
i will have to see if i can't make time to come see you next week as i am currently stuck at the hospital with my wife and daughter. pm me your number. i will check next week and see if you still have it before i come out.
Flatliner
Flatliner
BUMP still for sale
Flatliner
Flatliner
bump need out of garage make offer!
