FS: rebuilt 4t65e hd 0 miles
davevanoke
FS: rebuilt 4t65e hd 0 miles- 2 available
completely rebuilt 4t65e hd transmissions available with 2.93:1 final drive ratio for 97-2002 grand prix, regal, monte carlo, impala, bonneville, etc.... $895.00 each. must have core returned if local. the warranty is 1 yr. this is a stock 4t65e hd trans.
D
davevanoke
this fresh transmission is still available
DOC-Z
A person should NOT believe in an "ISM"
L.I.T.H./Huntley
the stock 4t65e can easily handle 400 horsepower. what kills transmissions are manual upshifting and downshifting and extreme burnouts
Really? I heard they were only good up to maybe 280-ish...and even that was pushing it, but the 4T80E is good to around 350 to 400.
D
davevanoke
i have close to 400 hp on my regal gs and my 4t65e hd holds up just fine
SleeperLS
Desert Racer
Sandia Mountain
Glws, not a bad deal IMO.
On a side note and not tryin to thread jack... iindividual parts will fail rather than the entire trans as I am sure you have seen. Some people seem to get luckier than others with stock stuff. Broke a stock input shaft with a bit under 280whp, blew up a aftermarket TC with between 280-300whp. The shaft broke in 1st, TC at the end of 2nd. Both runs were from a stop so no crazy shiftin occured
SleeperLS
Desert Racer
Sandia Mountain
Glws, not a bad deal IMO. Free Bump
On a side note and not tryin to thread jack... iindividual parts will fail rather than the entire trans as I am sure you have seen. Some people seem to get luckier than others with stock stuff. Broke a stock input shaft with a bit under 280whp, blew up a aftermarket TC with between 280-300whp. The shaft broke in 1st, TC at the end of 2nd. Both runs were from a stop so no crazy shiftin occured. I can't help but feel the tune has a decent impact on how the trans holds up too.
D
davevanoke
4t65e hd
stock with intense racing shift kit. gotta read the first thread
El Presidente
If you don't want the trans, move along.
D
davevanoke
4t65e hd 3 available
updated post. 3 4t65e hd transmissions are available now.
D
davevanoke
I see alot of people are looking at this thread but why isn't anyone interested in buying one?
TraptPatriot
Hammond
I think it would be better if you updated your first post and said that you can build upgraded transmissions as well, and list prices for that stuff.
$900 for a rebuilt stock trans is meh when you can get a Tim King fully built trans for $1900, and it has all the upgrades and goodies.
Just trying to help you out in why no one is interested...
Wessel
The Paint Corrector
JUST AN FYI..... U OPENED A CAN OF WORMS SAYING THIS. SO IT SEEMS LIKE UR TOSSING BUYERS A LOAD B.S. BY NOT ADDING UR MOD LIST TO = OUT TO ABOUT 400HP. JUST SAYIN.....
Wessel
The Paint Corrector
AND ANOTHER THING... EVERYONE ON HERE KNOWS WHAT MY GTP WAS RUNNING AND MY MODS. I HAD A STOCK TRANS WITH ONLY A SHIFT KIT NOTHING ELSE.
D
davevanoke
I guess i should be more careful when saying close to 400 hp
D
davevanoke
As far as experience I learned everything I know from my Dad when I worked for him at his auto repair shops where we rebuilt and installed alot of transmissions. I have over 25 years experience with engines and transmission work. my Dad is 87 now and no longer doing work but i decided to specialize with the 4t65e trans. I stand behind my work if you ever have a problem
these are the upgrades you will get for an upgraded 4t65e hd for $1850
7/8s single chain with your choice of 2:93,3:29 or 3:69 gearing
stronger performance input shaft
hardened 4th gear hub
transgo shift kit
raybestos blue plate performance clutches
steel channel plate gaskets
necessary valve body updates including borg warner epc
usa made filter
