FS: Older Car Stereo Equipment
TommyGloves
CHICAGO
Some old school equipment from a previous car stereo setup:
(2) Earthquake 12" EQ12-CPDS Subwoofers with Custom Enclosures $300
The enclosures are custom built for these subs 3/4" MDF with a 1.5" front baffle. Sealed design. Extensive 1x1 internal bracing. Thsse subs pounded using the Alpine amp listed below. I can't find the specs on these subs any longer. Each sub is in it's own enclosure that is design to be mounted together once in the trunk.
Alpine 3554 Amplifier $75
4 x 50W @ 4 ohms (0.08% THD)
4 x 75W @ 2 ohms (0.3% THD)
2 x 150W @ 4 ohms bridged (0.3% THD)
Fuse: 2 x 20A
Dimensions: 11.8" x 11.8" x 2.4"
Pioneer Premier GM-X622 $50
Specs here:
http://www.pioneerelectronics.com/pna/prod...DetailComponent
Pioneer 3-way Speaker Setup $50
1" Tweeters, 4" Midranges, 6.5" Woofers (includes an extra set of tweeters) no crossovers.
Pioneer CD-635 1.2 DIN 3-Way Crossover (jncludes wiring harness $25
Specs here:
http://www.pioneer.co.uk/uk/products/25/38...-635/index.html
Pioneer DEQ-9200 DIN DSP Audio Processor with Auto EQ (includes wiring harness) $100
Specs here:
http://pioneerelectronics.com/pna/v3/pg/pr...etailsComponent
Sherwood 3-Way Active Crossover $25
Pioneer Headunit DEH-7200(?) Cassette Detachable Face $20
Includes wiring harness and remote. Controls P-bus CD-changers
Everything is in good or like new condition. It's been in storage since I removed it from my previous car (91 Cutlass Supreme) a couple years a go.
I will consider offers and give discounts for mutliple item purchases. Pics available on request.
Thanks
TommyGloves
CHICAGO
Forgot some stuff...
1 Farad Cap with Lighting Audio Terminal Block $40
4 Gauge Inputs with 8 Gauge Outputs (4)
2 Monster Cable Fuse Blocks $10
Each holds 2 fuses and has 8 Gauge Inputs/Outputs
I also have a box of wiring that includes 4 pairs of 17' Monster Cable RCA cables. 4 Guage and 8 Gauge power wire. I'll be happy to provide whatever wiringg I can with the equipment listed above.
smknL67
Bensenville
What can you do for me if I take the 3 way eq and processor? I can meet you at woodfield like last time....
thanx
TommyGloves
CHICAGO
thanx
[/b]
Hey Paco - How about $110 for both? I sent a PM but not sure if it went through. I could meet up later today
EDIT: I've got 4 pairs of 17' Monster Cable Triple sheilded RCAs too. I'll throw those in for another $15. (I paid over $175 for these when new.) I ran these from the DEGH-9200 and CD-635 to the amps.
TommyGloves
CHICAGO
SOLD: Pioneer Headunit DEH-7200(?) Cassette Detachable Face $20
