FS : MP112 Supercharger + Intercooler kit.
jdredd
Addict
Jan 29, 2014
734
298
Anyone that still doinks with these things....
Selling kit for my friend Tyler.
Pulled off his 87 Fiero 3800 swap.
MP112 Supercharger + Intercooler Kit
Kit Includes:
All bolts and washers
MP112 SC and drive/TB Adapters (MP112 is better than the regular M112)
LS1 TB, LQ4 MAF, and Bellows and MINI AFC
Custom IC frame with Spearco IC core
AN-10 to AN-12 Adapters
KYGTP Belt Wrap Kit
Custom Snout Support that was used on the Fiero.
3.25" 8-Rib Pulley (Magnuson Keyed pulley)
Modified L67 Lower Intake Manifold
3 of the 8 Rib pulleys needed. One is a Mustang tensioner with pulley.
Includes a 8 rib belt that was used.
Will need to supply your own pump/front mount heat exchanger and such.
Will need 8 rib balancer
Will need gaskets.
Will need to reapply gasket/RTV between blower and TB adapter. Only together here for picture.
Will NOT part out. Its buy it all type deal.
Single pass at track was made for a 11.40@120, 14-15psi on stock sized all season street tires.
Think it was originally an Intense KIT that wasn't up to snuff..
IC frame modified by PRJ with a Spearco A/W IC core (same core as used in the original Thrasher ICs).
The water lines exit the core as AN-10 male fittings (A set of AN-12 adapters are currently fitted to these and will be included with the kit).
PRJ also modified the PCV routing so the system would function correctly. Bypass valve functions correctly, must be plumbed to your vacuum line routing.
The lower intake included in the kit was cut to accommodate the depth of the Spearco IC core as well.
The LS1 TB was modified in several ways, and factory throttle and cruise cables mate correctly to the bracket.
The system works with a KYGTP belt wrap kit that will be included.
The snout support was also custom made for the Fiero application. I think it will work on Wbodies using the kit but may require modification. It is not required for use and was not originally included in the Intense kit.
The kit is ready to bolt on your vehicle although as each application may vary, some modifications may be required.
$2100 shipped to lower 48. Paypal... (tack on the 2% if don't send as friend/family/whatever)
Ships from Erlanger, KY, 41018
jdredd
Addict
Jan 29, 2014
734
298
$2100 is getting better, CGP site says $2600.
Hmm wonder how much more it will go down?
Just haven't updated the site.. right now $2100 is about as low as we plan to go.
Worse case, ill buy it from him and sit on it... So we can continue work on the turdbo fiero.
We lowered it cause we saved $500 on a turbo we wanted.. so took that savings and dropped the price down.
Rent Free
24,425
20,277
Nowheresville North Dakota
:rofl: think you've gave him more than me? :dunno: Im at 2 cars and like 10k in parts.....
:fu:
The joke was when I went to pick up the caged car and the turbo kit last feb. that I was going to sign one of his landscaping blocks since I joked with him that I paid for that.....
Maybe you can sign on of the walls in his basement. :rofl: I believe that's all hes got left to finish on his house.
Damn Greg that's pretty funny actually. I wonder what he plans on doing with it? Reselling for a profit? He buys and resells more parts than anyone I've ever known of in the 3800 community.
I wonder if his Whipple car is done yet? I still think in the back of my head I'd like to own that one too. I was offered a price to buy it last year when I was at his house in Feb.
jdredd
Addict
Jan 29, 2014
734
298
:fu:
Eh, I might be $5-6k in parts .... the 2.93 GMR set alone was $2500 .... but I sold my 3.29 GMR for $1500..
Whipple car about back in action... I think waiting on one more pulley for the 10 rib setup.
Not 100% sure what the plan is with the MP112... he had a possible buyer for it.. so maybe playing the middle man on it.
