FS: DHP Tuning Setup (Laptop, DHP, PLX WB O2)
TommyGloves
CHICAGO
I'm selling one of my tuning setups. Selling as a package. Invest in yourself...become a 3800 tuning god!
You just need a good OBDII port, install the WB in your DP and 12v power and ground for the PLX wideband!
This is all setup and ready to go!
Dell Inspiron 700m Laptop
* Replaced LCD last year with a Dell replacement
* Newer, genuine Dell 8-cell battery (Battery is still healthy...see pic)
* Dell AC Adapter
* Fresh Windows 7 Pro (Dell OEM Activated) - Minimal software installed.
* 2GB RAM, 2.0ghz M CPU, Wifi, DVD Burner
* I've pre-installed all the DHP, UVScan 2 and 3, Tiny Tuner Suite, PCM files, tuning guides, tuning spreadsheets, etc.
*All drivers installed and tuning software setup out of the box
* Everything works and it's in great shape
DHP PowrTuner AVT-841
* Keyspan adapter included
* Pre-wired A/D Inputs (1: PLX WB O2, 2: PLX NB O2, 3: Open pigtail for a 3rd sensor or signal wire. I ran fuel pressure.)
PLX SM-AFR (Gen II)
* Newer Bosch Wideband O2 sensor (has ~1,000 miles on it)
* Just need to connect 12v power and ground
* Modified to allow a direct, digital serial communication (works with a special version of UVScan II installed on the laptop. It's the serial cable coming out of the PLX. Connects to a USB port on the laptop . https://forum.efilive.com/showthread.php?7726-PLX-SM-AFR-Serial-upgrade&p=129268&viewfull=1#post129268)
I'll include a Windows 7 Pro Recovery CD and backup CD of the tuner software.
Price: $500 picked up in Palatine
TommyGloves
CHICAGO
Goin' up on the big boards. I can't wait for all the..."Will you do $200 shipped?" "What can I tune with a DHP?" "Does the laptop play porn?" comments.
