Selling a 99 Regal GS, longtime owner was DoubleD on many pages. Purchased the car last summer from him and only have put a few hundred (maybe?) miles on it. Setup on e85 went 12.8 @ 108 with a 1.9x 60’, slip attached, as a non-IC heads/cam car. Car scaled back to daily mode on 93 and 3.2 pulley.
Car miles- 158,545. Engine has ~74k, trans ~55k.
S1x, MPS (also have a 3.5), LS6 springs, single roller chain, injectors, genV, Ported LIM, aluminum gaskets, ported heads, Pacesetters, custom exhaust, RVR control arms, wideband gauge.
Exterior- attached pics of 98/99 flake issue. Car was then entirely plasti-dipped by me in Sharkskin Gray with a flat black roof, base of avalanche gray under everything. I will include all the remaining gray dip for fix/touch-up. Just replaced window trim all around with like-new pieces, tinted head lights and tails.
Issues- Car needs ISS sensor replaced and intermittently has the ABS/trac light issue occur so the car does throw codes. Right rear brake-line rusted out, plugged that line at the ABS unit and did a brake flush to reset system, have not fixed line. Exhaust also is rusted and could use an overhaul/fix.
I drove the car to some distant meets and it was a daily driver for a long time for the previous owner until I purchased, so it does not have issues in that regard. Added a new battery and wipers, only thing it could use for comfort is an a/c recharge.
Added pics of rockers and strut towers as that is always such a major issue you see with these cars.
Car’s original 16s have old BFG Traction T/As that might be ok to store on that will come with the car, but I will have the car on 17” powdercoated black Comp G rims with Blizzaks on them. I also have a set (the current pictures of the car) of 18” Fittipaldi Force wheels that are plasti-dipped Brass Monkey that I will include with the car for the right price or sell separately, just dropped $450 on brand new 245/45/18 tires for the set. I will also include a couple cans for touch up purposes as any touching of the lugs causes wearing of the dip right around the nut. I will also include a bunch of extra 3800 parts that I have in the trunk, mostly stock replacement type parts for the car.
$1,500 for everything minus the 18s*
