đź’ˇ Fun fact. Whenever you start a thread, TCG Mechanic 5000 (our AI bot) will reply to you to start helping. It doesn't know everything and it will struggle with more complex questions but it can get the thread going and provide valuable information. You can choose to disable it prior to submitting a thread.
Do you have to replace the nut that holds the front wheel bearing hub on when you replace the hub and how many foot lbs of torque dose it take to tighten it and where can you buy a new one and what is the cost of the nut thank you Ron
I replaced both front wheel bearings and had the same debate but I went ahead and reused.......btw if you dont have a 36mm socket and torque wrench you can rent them from Autozone:biggthump
