front control arm bushings
Mystic Terminator
3,150
Don't do it, I highly doubt it will make a difference. Plus I believe they have to be pressed out.
My control arms were more work than the IRS cradle bushings. I had to burn them out and it was a bitch. It was very time-consuming to do it all. Do not use urethane for an articulating joint, use delrin. FRPP sells delrin bushings for the control arms.
They also sell extended ball joints (Like the Steela X2) that you can do @ the same time.
Jimy Bilmo
CSVT OG Member
TCG Goldmember
61,352
