Found some broken stuff, worn out stuff, leaking stuff. Need advice.
Zack
4 Doors 4 Life
NW Indiana
Forgive me if these are common problems, its all new to me. :)
First, wet around the steering shaft. Is this something I should repair, or is it common on Cobra's?
Next, broken motor mount. Im not surprised, the drivers side was already replaced.
Good thing I had these laying around:
Next, lower control arm bushings.... The front bushings do not seem right to me. Do they commonly wear out? I was gonna pull the springs tonight to cut them, but Id like to repair/upgrade/leave them alone all at the same time. Please give me your input:
Thanks in advance :biggthump
IZZy
Powered by ES
I wouldnt worry about the bushings but that steering shaft shouldnt be that bad
rdsnake
formerly RD SNAKE
zack, I haven't seen any leaking steering racks. I'm sure you could get a used unit somewhere for cheap. Its the the time to change it if the motor is out.
The lower control arm bushing look normal
Zack
Zack
4 Doors 4 Life
NW Indiana
Thanks guys.
My Ford parts guy is analyzing the parts diagram now to see if a seal is avaliable.
Ill give that a whirl first before I go replacing entire assembloes.
